Go to Post Defense will be everybody's part time job, not their career. - Wayne TenBrink [more]
Unread 28-01-2016, 15:34
Re: Problems driving straight.
Originally Posted by Daniel_LaFleur View Post
A really tight or loose roller will cause your robot to veer off
That made me think of an experiment for which I'd be quite interested to see the results.
Take a well-crafted mecanum bot that drives fairly straight without the need for any closed loop control.
Tighten all the rollers on the left-side wheels and see what effect that has on forward-only commands on both carpet and hard flooring.
Do you think it would
a) still drive straight
b) veer to the left
c) veer to the right
d) do different things on carpet vs hard flooring
Give a rationale for your answer.
Unread 28-01-2016, 19:51
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
b) veer to the left
I'd like to see that experiment as well.
My guess would be a slight turn to the right ("C") as the vector addition on the left side (both straight forward) would be greater than the vector addition on the right side (1 @ 45 degrees right plus 1 at 45 degrees left). I'm just not sure if it would be enough of a difference to cause it to turn.
My post before was for a single mecanum wheel roller set to be tight (or significantly different from the others).
___________________
- Tennyson, Ulysses
Unread 29-01-2016, 00:24
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
b) veer to the left
I'm going to say the robot will veer to the right. Even when driving straight the mecanums should inevitably experience a little bit of slip with rollers. Preventing the rollers from moving will prevent this slip, so you effectively get more forward movement per wheel rotation on the left compared to the right.
I'm envisioning a person walking on an inclined sidewalk which is half covered in snow, and half dry. One foot on the pavement, the other in the snow. The foot in snow will "slip" back a bit with every step, but the foot on pavement gives you the full stride.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 29-01-2016, 09:23
Racer26 Racer26 is offline
I'd be inclined to agree. I could also see a possibility for a performance difference between hard floors like tile or concrete and softer ones like carpet. I would think the locked roller side would get even more traction on carpet than on the hard floor and make the effect even more pronounced.
Unread 29-01-2016, 18:03
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Originally Posted by Eloy1073 View Post
An Xbox afterglow controller.
I was going to provide you the link to the calibration process but school internet blocks sites that are related to gaming. Just google Xbox Afterglow controller calibration and it should be the first link.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
