Go to Post Brandon is my hero :) - Cory [more]
Unread 28-01-2016, 20:00
Blizzard3197 Blizzard3197 is offline
FRC #3197 (HexHounds)
Blizzard3197 is an unknown quantity at this point
Re: Bumper Update
I think you're confusing "length of metal in my robot's frame" with Frame Perimeter.
And I REALLY hope I'm right, because that could catch you.
So, here's my question to you: If you stretch a string around your robot right now, in the bumper zone, is it 120" or less? And, how wide is the gap currently? (And the side length, if you don't mind.)
Also, one other suggestion: read the rules on "support" of bumpers again.
Okay, so the gap for the ball is 10-12 inches, right? And the rules state that there must be 8 inches on either side of the opening from the corner out, like figure 4-3, bottom left robot. So 10+8+8=26, which is a lot. And that would not work for our previous diagram for our robot.
Though we're playing around with the idea of an arm/sucker combo with wheels to suck up the ball and the arm to aim.
Unread 28-01-2016, 20:04
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Bumper Update
Your math is correct. If you want to bring the ball in, through the bumpers, at the balls widest point then you need at least 26" (10"+8"+8") of frame perimeter on that side.
___________________
- Tennyson, Ulysses
Unread 28-01-2016, 20:07
Happy Birthday! EricH EricH is offline
Re: Bumper Update
I didn't ask for how it would affect you. I asked for the NOW dimension. Read: As your robot sits right now, in CAD or in "person", is it <= 120"? And what exactly are you working with for dimensions? There may be ways to adjust to be able to use a gap.
BTW, 26" is actually a rather narrow robot, even under frame perimeter being the dimensional driver. Many teams will build more "square" robots.
Unread 28-01-2016, 20:21
Re: Bumper Update
Hm.. I'd have to talk with the lead CADer...
It was 21" x 35".
Which, for the front to have the necessary width, we'd have to add 5 inches. 26 x 35 would = 122 (greater than 120), so if we take 2 inches from the back, we'd have 26 x 33 = 118 (which would fit).
And it'd be square...
However, trying to fit a 10" ball into a 10" hole would be practically impossible, so bump the hole up to 12", take 2 away from length, which would be 31 x 28 = 118. However, add 6 inches of bumper, and it wouldn't fit into the batter near the tower, making the low goal/climbing practically impossible.
And that's why we aren't going in that direction. Sorry for the miscommunication.
Unread 28-01-2016, 20:43
Re: Bumper Update
Ah, that makes more sense.
I'd definitely go over-bumper in that case. 10" ball, 15" to work with-3.25" for bumper width, so there's about an inch to play with on the far side of the ball. You could also leave a gap in the bumper to help center the ball going over. You'd have about 5" of gap available if you opted to use it, which could also make it possible for a full-height bumper to let the ball go under. (Haven't measured a ball to check.)
Decisions, decisions... seems like some prototyping might be in order.
Unread 28-01-2016, 20:47
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bumper Update
see the video link in my post above. you don't need a gap to get a ball under the bumper, if the bumper is at the top of the BUMPER ZONE. that's one of the very first things I wanted to test when I saw the game...
Unread 29-01-2016, 11:16
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Bumper Update
It was 21" x 35".
Yes, your math is correct (what did you mean by "square"). We are planning a 31 long x 28 wide (plus an 1/8 for sheathing for 118.5" perimeter). The longer wheel base has a shallower tilt angle as it goes over the defenses (less tippy) and as you noted has a better chance of getting on the batter.
Why do you think the 28" + 6" side wont fit against the tower on the batter? Is your 28" the width or length?
Unread 29-01-2016, 19:54
Re: Bumper Update
By square I mean rectangular.
31 wide 28 long, though we're working now with more of a trapezoid shape, with angled sides. I'm not entirely sure why this design wouldn't fit onto the batter. Maybe it'd get stuck on the large, angled surface?
Unread 11-02-2016, 09:16
FRC #1559
Re: Bumper Update
double check the space between the dividers on the batter. I did not find a dimension, but they look to be 2'6" close to the tower - which will fit a 28" wide robot (assuming bumpers higher than divider) up against the tower, but not a 31". If you dont plan on scaling the tower, it may not matter.
