Go to Post I am allergic to work... - Mike Schroeder [more]
Unread 28-01-2016, 22:16
Txuritan Txuritan is offline
FRC #5612
Txuritan is an unknown quantity at this point
Question Changing rear drive motors max output
Forewarning my team recently switched from Java to LabView so I know little to none of the language.
We currently have a problem in which the two rear motors have a different gear ratio than the front two, the rear has to be set to 75% and the front is keep at 100%, the only way I can thin of fixing this is to rewrite the Talon control VI and I wanted to know if had a better way of fixing it.
It is an arcade drive system using the basic setup given to you as a starter project.
Unread 29-01-2016, 12:29
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Changing rear drive motors max output
Sounds like a poor mechanical design decision, but that's your robot, not mine.
You can multiply the output by 0.75 before feeding that into the Motor Set Output vi.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
