Re: FRC Sonar Reading Delays
here's our code.
We're using the analog sonar from MaxBotix package org.usfirst.frc.team1635.robot.subsystems; import org.usfirst.frc.team1635.robot.RobotMap; import org.usfirst.frc.team1635.robot.commands.DriveWithJ oystick; import NavxMXP.AHRS; import edu.wpi.first.wpilibj.AnalogInput; import edu.wpi.first.wpilibj.DigitalInput; import edu.wpi.first.wpilibj.DigitalOutput; import edu.wpi.first.wpilibj.Joystick; import edu.wpi.first.wpilibj.RobotDrive; import edu.wpi.first.wpilibj.SerialPort; import edu.wpi.first.wpilibj.SpeedController; import edu.wpi.first.wpilibj.Timer; import edu.wpi.first.wpilibj.Victor; import edu.wpi.first.wpilibj.RobotDrive.MotorType; import edu.wpi.first.wpilibj.command.Subsystem; import edu.wpi.first.wpilibj.livewindow.LiveWindow; import edu.wpi.first.wpilibj.smartdashboard.SmartDashboar d; import edu.wpi.first.wpilibj.Ultrasonic; /** * @author Xxx_MrProLi_xxX & _Pussyslayer_Miguel & Simranj69t * * */ public class DriveTrain extends Subsystem { RobotDrive robotDrive; Joystick stick; // int frontLeft, frontRight, rearLeft, rearRight; private SpeedController frontLeft, backLeft, frontRight, backRight; boolean onTarget; SerialPort serial_port; // IMU imu; // This class can be used w/nav6 and navX MXP. // IMUAdvanced imu; // This class can be used w/nav6 and navX MXP. AHRS imu; // This class can only be used w/the navX MXP. boolean first_iteration; // Ultrasonic sonar; AnalogInput sonar; double DistanceToStop; double Degrees; // analog // Put methods for controlling this subsystem // here. Call these from Commands. public DriveTrain() { super(); // DigitalInput echoChannel; // DigitalInput pingChannel; // sonar = new Ultrasonic(0, 1); sonar = new AnalogInput(0); // frontLeft = RobotMap.frontLeftChannel; // frontRight = RobotMap.frontRightChannel; // rearLeft = RobotMap.rearLeftChannel; // rearRight = RobotMap.rearRightChannel; frontLeft = new Victor(RobotMap.frontLeftChannel); backLeft = new Victor(RobotMap.rearLeftChannel); frontRight = new Victor(RobotMap.frontRightChannel); backRight = new Victor(RobotMap.rearRightChannel); robotDrive = new RobotDrive(frontLeft, backLeft, frontRight, backRight); robotDrive.setExpiration(0.1); robotDrive.setInvertedMotor(MotorType.kFrontRight, true); // invert the // left side // motors robotDrive.setInvertedMotor(MotorType.kRearRight, true); // robotDrive.setInvertedMotor(MotorType.kRearLeft, true); try { serial_port = new SerialPort(57600, SerialPort.Port.kMXP); byte update_rate_hz = 50; // imu = new IMU(serial_port,update_rate_hz); // imu = new IMUAdvanced(serial_port,update_rate_hz); imu = new AHRS(serial_port, update_rate_hz); } catch (Exception ex) { ex.printStackTrace(); } if (imu != null) { LiveWindow.addSensor("IMU", "Gyro", imu); } first_iteration = true; // When calibration has completed, zero the yaw // Calibration is complete approaximately 20 seconds // after the robot is powered on. During calibration, // the robot should be still boolean is_calibrating = imu.isCalibrating(); if (first_iteration && !is_calibrating) { Timer.delay(0.3); imu.zeroYaw(); first_iteration = false; } } /* * to obtain the gyro value in degrees */ public double obtainYaw() { return imu.getYaw(); } public float convertToFarenheit() { float celcius = imu.getTempC(); float farenheit = (float) (celcius * 1.8 + 32); return farenheit; } public void log() { SmartDashboard.putNumber("Gyro", obtainYaw()); SmartDashboard.putNumber("Temperature", convertToFarenheit()); SmartDashboard.putNumber("FrontLeftMotorSpd", frontLeft.get()); SmartDashboard.putNumber("FrontRightMotorSpd", frontRight.get()); SmartDashboard.putNumber("RearLeftMotorSpd", backLeft.get()); SmartDashboard.putNumber("RearRightMotorSpd", backRight.get()); SmartDashboard.putNumber("DistanceSonar", getDistanceSonar()); // SmartDashboard.putNumber("", getDistanceSonar()); } // codes for the mecanum drive public void mecanumDrive(Joystick joy) { //robotDrive.mecanumDrive_Cartesian(-joy.getX() * 0.6, -joy.getY() * 0.6, -joy.getRawAxis(3) * 0.6, 0); robotDrive.mecanumDrive_Cartesian(-joy.getX()*3 , -joy.getY()*3, -joy.getRawAxis(3)*3, 0); // robotDrive.mecanumDrive_Cartesian(-joy.getX() * 0.6, -joy.getY() * // 0.6, // 0, 0); SmartDashboard.putNumber("Xdirection_values", joy.getX()); SmartDashboard.putNumber("rotation_xxx_value", joy.getRawAxis(3)); } public void mecanumFixed(Joystick joy) { if (joy.getX() != 0 && joy.getY() == 0 && joy.getRawAxis(3) == 0) { if (joy.getX() < 0) { robotDrive.mecanumDrive_Cartesian(-joy.getX() * 0.6, 0, 0, 0); backLeft.set(frontLeft.get() * 2); frontRight.set(frontLeft.get() * 2); // frontRight.set(speed); // frontLeft.set(speed); // backLeft.set(speed); // backleft.set } else if (joy.getX() > 0) { robotDrive.mecanumDrive_Cartesian(0, -joy.getY() * 0.6, -joy.getRawAxis(3) * 0.6, 0); backLeft.set(frontLeft.get() * 2); frontRight.set(frontLeft.get() * 2); } } else if (joy.getX() == 0) { robotDrive.mecanumDrive_Cartesian(-joy.getX() * 0.6, -joy.getY() * 0.6, -joy.getRawAxis(3) * 0.6, 0); } } /* * * this code is designed to obtain the distance from the * xxx_MLG_NEXus_LI_XXX_#360n0SC()P3 */ public double getDistanceSonar() {// sonar is weird: it has a deadzone of 12 // inches; distance will always be 0 // within the deadzone // double distance = sonar.getRangeInches(); // double distance = sonar.getValue(); //double valueToInches = 0.125; double valueToInches_2 = 1 / 20.5;// 14.45 double distanceX = sonar.getAverageValue(); double distance = (distanceX - 237) * valueToInches_2 + 12; // convert // voltage // into // inches int distanceInt=(int) distance; return distanceInt; } public void setDistToStop(double dist_) { this.DistanceToStop = dist_; } public void stopRobotAtDistance() { double distanceObtained; // getDistanceSonar()= 0 ; distanceObtained = getDistanceSonar(); if (distanceObtained <= DistanceToStop) { robotDrive.mecanumDrive_Cartesian(0, 0, 0, 0); onTarget = true; System.out.println(" is robot finished " + true); } else { // Timer.delay(0.05);// compensate for sonar reading delays robotDrive.mecanumDrive_Cartesian(0, 0.2, 0, 0); // xxx_delayMecanum(0, 0.2, 0, 0); System.out.println(" is robot finished " + false); } } public void mecanumWithParameters(double x_axis, double y_axis, double rotaion) { robotDrive.mecanumDrive_Cartesian(-x_axis * 0.6, -y_axis * 0.6, -rotaion * 0.6, 0); } public void initDefaultCommand() { this.setDefaultCommand(new DriveWithJoystick()); // Set the default command for a subsystem here. // setDefaultCommand(new MySpecialCommand()); } public boolean isOnTarget() { return onTarget; } public void reset() { imu.zeroYaw(); //sonar.resetAccumulator(); onTarget = false; // getDistanceSonar()=0; } public void stop() { robotDrive.mecanumDrive_Cartesian(0, 0, 0, 0); reset(); } |
