Go to Post The day I walk down the street and overhear a conversation like "Hey, did you check out Andy's new gearbox design yet?" ... - Aignam [more]
Unread 12-01-2016, 08:08
waffle_dynasty waffle_dynasty is offline
FRC #5010
waffle_dynasty is an unknown quantity at this point
Hanging Bar (Team Version)
Has anyone made the Hanging Bar and tested to see if the all wood construction will hold up a robot? To me it looks like the dowel rod could break or the whole thing could bend causing the height to be lower than it should be.
Also, does the team version Hanging Bar fit well into the team version Castle?
Unread 12-01-2016, 08:10
James Juncker's Avatar
James Juncker James Juncker is offline
Broken Robot Fixer
FRC #2834 (Bionic Black Hawks)
Team Role: Driver
James Juncker will become famous soon enough
Re: Hanging Bar (Team Version)
Our team has the element built from hosting a kickoff event, I have personally tested the dowel rod with the same concern. I am glad to say that it was able to hold my 170 pounds for 3 pull ups (very scientific) but the dowel rod should be sturdy enough.
as for the dowel under the tower... I should be possible to combine the two it will just require more work to cut out sections of the tower/hanging bar.
The FRC season has 3 steps
Eat
Build
Play
It is important to note that sleep is not included in these steps.
Unread 28-01-2016, 16:09
bobl bobl is offline
FRC #0058 (The Riot Crew)
bobl will become famous soon enough
The bar is quite sturdy. HOWEVER, the width of the bar is 24" and all of it is open for testing. The actual game element is 21" wide to the outside and if I'm reading the plans correctly it's only 18" inside (The bar is 1.5" Schedule 40 Steel, 21-(1.5x2)=18).
Plan accordingly.
Unread 28-01-2016, 16:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
1-1/2" Schedule 40 pipe is quite a bit larger than 1.5" outside diameter.
Unread 28-01-2016, 16:12
Quite right, so it is less than 18" between the standoffs.
Unread 28-01-2016, 16:17
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The bar is not schedule 40 pipe, it is 1.5" DOM tubing with an actual OD of 1.5"
--Madison--
...down at the Ozdust!
Unread 28-01-2016, 20:50
MrForbes's Avatar
AKA: Jim
Thanks for the clarification.
Unread 28-01-2016, 21:24
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
We made one out of galvanized pipe and mounted it to the wall to be safe. It was expensive though.
Unread 28-01-2016, 22:41
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant futureRetired Starman has a brilliant future
We are going to mount bars under our team built tower for one of Peachtree Region's Destination Einstein practice fields.
I purchased a 10 ft. length of 1 1/4 in thin wall conduit from Home Depot for less than $11.00. It has an outside diameter of 1.510 in. which is very close to the DOM tubing which should be 1.500 in.
DOM is smooth on the inside, hence it is used by FIRST in field elements that have to slide together. For our practice purposes, you don't need to go to the expense of using DOM since we are only interested in hanging on the outside. If you need something more precise than the conduit I mentioned above, you can go with ERW tubing. Identical to DOM on the outside, ERW has a small ridge inside where the welding was done.
For my money, I can live with 10 thousands of an inch oversize. There may be teams, however, who need the precision of the DOM. Hope they have a budget for it!
Dr. Bob
Dr. Bob
Chairman's Award is not about building the robot. Every team builds a robot.
Unread 28-01-2016, 23:06
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Dr. Bob
This was exactly our reasoning for Aerial Ascent (2013). We built our practice pyramid out of rigid conduit.
