Go to Post So Love your robot, and it will love you. - Not2B [more]
Unread 28-01-2016, 23:43
MAXOFLIFE's Avatar
MAXOFLIFE MAXOFLIFE is offline
Bolton Bear Bots Member
AKA: Maxwell Huffman
FRC #3666 (Bolton Bear Bots)
MAXOFLIFE is an unknown quantity at this point
Help with Purchasing Correct Pulley
My team and I are connecting a miniCIM to a 100:1 versaplanetary gearbox, to a 10 tooth pulley to a 60 tooth pulley to give us an overall ratio of 600:1 for our arm mechanism.
We've went to SDP/SI for our pulleys but we are new to this type of mechanism and are unsure of what exact components we will need to make sure everything connects correctly.
Here are the two pulleys (10 and 60 tooth, both with double flange)
http://sdp-si.com/ss/pdf/81002029.pdf
What components do we need to purchase with our versaplanetary gearbox kit so that it will connect to the 10 tooth pulley and what do we need to buy to mount the 60 tooth pulley to our 1/2" hex rod?
Thank you for the help!
Unread 28-01-2016, 23:52
asid61's Avatar
asid61 asid61 is online now
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Help with Purchasing Correct Pulley
You would need a 1/2" hex broach or turn down the 1/2" hex to the bore of the pulleys.
I would recommend using #25 chain and sprockets instead, or even #35, as it is readily available at Vex and Andymark, is much more forgiving in terms of strength and precision, and comes in 1/2" hex bore sizes.
EDIT: Those are MXL pulleys, which are not commonly used due to their lower working load. GT2 or HTD pulleys are generally better for our purposes.
Unread 29-01-2016, 00:05
MAXOFLIFE's Avatar
If we were to switch to chain on VEX, could you recommend a setup with approximately 600:1 using vex components? Using a 12t to a 60t would work for our purposes, but I don't think we can spare the 7 inches for the 60t sprocket.
Would it be ridiculous to connect 3 versaplanetary gearboxes and avoid large sprockets altogether?
Thanks for the help!
Unread 29-01-2016, 00:12
Knufire Knufire is online now
At 100:1, you are already exceeding the maximum rated load of the Versaplanetary. See the load rating guide here: http://content.vexrobotics.com/vexpr...s-20151221.pdf
Geared this far down, you're looking at some pretty large amounts of torque. I'd definitely prefer to go chain over belt, and might even want to step up to #35 chain.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 29-01-2016, 00:28
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
I didn't see where the load of the arm was posted. a 600:1 reduction doesn't necessarily exceed the load rating.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 29-01-2016, 00:38
Imaginary Friend
AKA: Kevin Li
Team Role: Student
It doesn't look like you can attatch a 10 tooth pulley to a half inch hex rod. The 10Tooth Pulley (A 6A16-010DF2504) has a OD of .235 inches.
Kevin Li
596 - Sciclones
Unread 29-01-2016, 00:47
Ideally, yes. But as soon as the arm attempts to drive itself into a hard stop due to a bug in the code, tries to rotate against a field element or another robot on the field, etc, you'll see much higher than the intended load. Cracking the carrier plate inside a VP isn't my cup of tea when it comes to failure modes.
Unread 29-01-2016, 01:25
asid61's Avatar
AKA: Anand Rajamani
FRC #0115 (MVRT)
You are exceeding the load only if you stall out the motor. Placing a current limit or voltage limit on the motor will stop that from occurring. Theoretically at hose ratios one could use a BAG motor or something smaller, but the greater mass of a minicim or CIM makes it a bit safer.
Unread 29-01-2016, 05:55
DaveL DaveL is offline
FRC #2976
DaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the roughDaveL is a jewel in the rough
If you want to go with a belt, you can try the Gates calculator.
http://ww2.gates.com/first/resources.html
I like Gates belts for the drive train and I've found belts to also work well for low force applications like an intake roller.
In 2014 we used chain to transfer motor torque on our shooting arm. Chain is more tolerant of lateral mis-alignment and the tension variation than belts.
Dave
Unread 29-01-2016, 09:46
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
600:1 is huge. Are you sure you need that much torque? If you want to stay with belts, you definitely need to use the wider 18mm belts and pulleys.
To stay close to your original design (333:1 instead of 600:1) Vex has some great pulleys already broached for the 1/2 hex - smallest is 18T. http://www.vexrobotics.com/vexpro/mo...tdpulleys.html Also they have light weight 60T http://www.vexrobotics.com/vexpro/mo...rsapulley.html Most importantly, they have a calculator that is set up for these stock parts to help you pick the correct belt for you pulley pitch http://www.wcproducts.net/how-to-belts/
