Go to Post 2004 qualifies as vintage now? Ugh. - Lil' Lavery [more]
Unread 29-01-2016, 08:07
Re: Noob question for teleop
Originally Posted by mmaunu View Post
This assumes that the gyro is plugged in to analog input 2 (which is the third port).
The Analog Accumulators required for the gyro are only on ports 0 and 1.
Unread 29-01-2016, 09:33
CjDace CjDace is offline
FRC #4284
CjDace is an unknown quantity at this point
Is the analog input in the roboRio directly next to the Ethernet port? there are ones farther down that are titled analog but our gyro/accelerator only fits in the one next to the Ethernet port. Is this correct? Thanks for the reply, our team is brand new every year so its hard to keep knowledgeable people around for long
Unread 29-01-2016, 11:23
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
So the one next to the ethernet is SPI. What gyro are you using?
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 29-01-2016, 13:57
FRC #4284
This is the gyro we are using as of now.
http://firstchoicebyandymark.com/fc16-000
Unread 29-01-2016, 15:34
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
For that gyro, you are connected to the correct port (the onboard SPI port). To construct a gyro object in code, you will want to use the Java class that was built specifically for this gyro:
http://first.wpi.edu/FRC/roborio/rel...S450_Gyro.html
You should be able to use the default (no parameter) constructor.
gyro = new ADXRS450_Gyro();
Now, in your drive code's call to the mecanum_Cartesian() method, you should be able to use gyro.getAngle().
Keep asking if it ain't working.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
Unread 29-01-2016, 15:58
FRC #4284
Thank you so much our team and I greatly appreciate your help and will ask for help in the future.
