Go to Post Wait, we have to be logical? - JaneYoung [more]
  #31   Spotlight this post!
Unread 29-01-2016, 02:21
Knufire Knufire is offline
Re: Andymark rhino drivetrain discussion
Originally Posted by Tom Line View Post
A whole lot of teams are going to be a whole lot of disappointed if those treads slide off when pushed sideways.....
And a whole lot of teams are going to learn how to play some pretty effective defense.
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
  #32   Spotlight this post!
Unread 29-01-2016, 08:13
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
The Rhino treads are very well secured and will be extremely difficult to knock off so long as the robot's pit crew keeps up with standard maintenance checks and makes sure that everything is kept tight.... Assuming proper upkeep, it would take a tremendous hit to cause any problems.... No, we don't intend to subject our robot to too many violent hits before competition...
At the same time, we recognize that there is a potential weakness here, so are developing game play strategies that will minimize such collisions.... Robot damage happens, no matter how robust your design might be... We even had our chassis bent at a district event last year - due to a violent autonomous collision with a member of our own alliance who's routine went haywire in a very bad way.....
  #33   Spotlight this post!
Unread 29-01-2016, 08:56
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
I am pretty confident the tracks will stay on when pushed from the side. The pulleys have a V groove which the the belt has an inverted v that fits in the groove. Is it possible that they could slide off when pushed from the side and the bot is trying to move forward or backward? Sure it's possible, but if the drive just lays off the controls for a couple seconds they won't "slide" off. Keep in mind someone can only push for 5 seconds and then has to back off.
  #34   Spotlight this post!
Unread 29-01-2016, 09:06
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I too am interested to see how these treads work out with full-weight robots, especially with open-field hits.
What makes me nervous is the turnbuckle used to tension the treads that relies on the eyelets to stay bent closed. The first thing I would do with one of those tread modules is to weld those eyelets closed. My intuition is that it will only take one or two hits to open those up.
Of course, I might be completely wrong...
You might want to check G22... ROBOTS can only pin for 5s. I think that you would have a hard time arguing that being pushed in an open field counts as a PIN.
  #35   Spotlight this post!
Unread 29-01-2016, 09:12
dradel's Avatar
Granted, but where is this open field you refer to?? It isn't like the Airial assist field! A quick back up or move forward and your touching the outer defense and bam foul.
Now I'm not saying there won't be defense played hard this year, but the potential for hits like in 2014 are going to be rare. Plus I would think most would be more worried on breaking defenses and or scoring in the tower. But we shall see
  #36   Spotlight this post!
Unread 29-01-2016, 09:30
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Therein lies the rub.
An open-field pin, or more precisely: an open field t-bone, doesn't require a high-speed impact. All it requires is a defender applying steady pressure to the side of another robot to completely ruin their ability to maneuver. I would encourage you to try this out with two or more robots, it is comically effective and easy to do.
  #37   Spotlight this post!
Unread 29-01-2016, 09:32
RacerX's Avatar
RacerX RacerX is offline
FRC #0948 (NRG948)
RacerX is on a distinguished road
The turnbuckles are in compression to keep the belt tight, not in tension. It would take quite a bit to get to the point where the eye bolts are opening. If things get that out of hand, the eye bolts opening will likely be the least of our worries....
As a suggestion, it would be a good idea to have jam nuts on one end of the turnbuckles to make sure they stay where you want them.
  #38   Spotlight this post!
Unread 29-01-2016, 09:37
dradel's Avatar
I understand what you are saying, but when I hear (read) T-bone I am thinking full speed violent hit. But I see your point. I know we will be testing that hopefully this weekend. Will try and grab some video to post here.
  #39   Spotlight this post!
Unread 29-01-2016, 10:07
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I know that the turnbuckles are in compression, which is what concerns me. It may be fine as-is, but the 2 grams of mass it would take to weld it closed seem more than worth it to me.
  #40   Spotlight this post!
Unread 29-01-2016, 11:25
dradel's Avatar
I hadn't thought about them opening up, which is plausible if a hard impact is taken on the front. And now that I think about it I will be welding ours.
  #41   Spotlight this post!
Unread 29-01-2016, 13:29
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
I would be more worried about weakening the aluminum at the weld. We at AndyMark did extensive hit tests on these turnbuckles at full speed with a fully weighted chassis into a piece of diamond plate that was backed by a full pallet of roller chain, so it had no where to go. We are working on putting up some videos of our testing so that the community can see what we have done to test the modules before we were comfortable selling them.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
  #42   Spotlight this post!
Unread 29-01-2016, 13:43
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Jon,
As part of your video tests, can you run a test of the Rhino track system being pushed sideways by another robot (both at 140lbs)? Specifically:
Robot A - Rhino Tracks (~140lbs)
Robot B - Kitbot (~140lbs)
Robot B pushes square onto the side of Robot A.
Robot A does not move.
As Robot B pushes Robot A, Robot A attempts to drive forward/backward.
If you could test the above scenario, that would be awesome!
Thanks,
-Mike
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
  #43   Spotlight this post!
Unread 29-01-2016, 15:38
RacerX's Avatar
FRC #0948 (NRG948)
If it becomes an issue with the tread being pushed off the wheels with side load, which I doubt will happen with a properly tensioned belt, can the Rhino Teams add a plate to the sides of the wheels, slightly larger than the wheel, so it overlaps the white part of the belt?
This would be similar to the other belt pulleys that are used.
In addition to the plates, perhaps a mechanism to deflate pneumatic tires could also be added?
  #44   Spotlight this post!
Unread 29-01-2016, 16:34
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Not comparable. Treads coming off a tread drive (ANY tread drive) from base to base interaction is a chassis that cannot withstand the rigors of FRC. Poking holes in pneumatic wheels is damaging and deliberate contact inside the frame perimeter.
Causing a team with under inflated tires to pinchflat under heavy defense is the parallel.
I'd be very interested in seeing the results of the test Mike has outlined.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
  #45   Spotlight this post!
Unread 29-01-2016, 16:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
The eyelets in the turnbuckles are aluminum? What alloy?
They appear as zinc-plated steel eyelets with an aluminum body, but you would of course know better!
Posting test videos would be a great way to address concerns of their robustness given the long the somewhat sordid history of treads in FRC drives. I look forward to seeing them!
