Re: Cabling between Talon SRX and VersaPlanetary Integrated Encoder
I believe that this connector is a lot closer, if not the same connector as the ones from CTRE or VEX. The width is 10.58mm. We were trying to decide what to use our digikey voucher on, and now we know what we will get. |
support@crosstheroadelectronics.com is your friend.
Omar will respond less than a day, and probably within seconds if it is between 8pm and 3am ![]() |
We just received our Digi-key voucher and things behave the same as when we were running our speed control loops using a cable purchased from CTR.
We did end up using a scalpel to take off a tab on the side in order to fit it into the SRX. Good luck! |
Joe, thanks for the follow-up feedback!
