Go to Post Engineers are not eligible to join NEMO, but that's OK! For us, there is an ad-hoc disorganization, notionally dubbed EMO. Meetings have no agenda and are called at random, usually in the evenings following long days at FIRST events. - Richard Wallace [more]
Unread 28-01-2016, 20:43
Re: Bumper Update
Ah, that makes more sense.
I'd definitely go over-bumper in that case. 10" ball, 15" to work with-3.25" for bumper width, so there's about an inch to play with on the far side of the ball. You could also leave a gap in the bumper to help center the ball going over. You'd have about 5" of gap available if you opted to use it, which could also make it possible for a full-height bumper to let the ball go under. (Haven't measured a ball to check.)
Decisions, decisions... seems like some prototyping might be in order.
Unread 28-01-2016, 20:47
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Bumper Update
see the video link in my post above. you don't need a gap to get a ball under the bumper, if the bumper is at the top of the BUMPER ZONE. that's one of the very first things I wanted to test when I saw the game...
Unread 29-01-2016, 11:16
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Re: Bumper Update
Originally Posted by Blizzard3197 View Post
Hm.. I'd have to talk with the lead CADer...
It was 21" x 35".
Which, for the front to have the necessary width, we'd have to add 5 inches. 26 x 35 would = 122 (greater than 120), so if we take 2 inches from the back, we'd have 26 x 33 = 118 (which would fit).
And it'd be square...
However, trying to fit a 10" ball into a 10" hole would be practically impossible, so bump the hole up to 12", take 2 away from length, which would be 31 x 28 = 118. However, add 6 inches of bumper, and it wouldn't fit into the batter near the tower, making the low goal/climbing practically impossible.
And that's why we aren't going in that direction. Sorry for the miscommunication.
Yes, your math is correct (what did you mean by "square"). We are planning a 31 long x 28 wide (plus an 1/8 for sheathing for 118.5" perimeter). The longer wheel base has a shallower tilt angle as it goes over the defenses (less tippy) and as you noted has a better chance of getting on the batter.
Why do you think the 28" + 6" side wont fit against the tower on the batter? Is your 28" the width or length?
Unread 29-01-2016, 19:54
Blizzard3197 Blizzard3197 is offline
FRC #3197 (HexHounds)
Blizzard3197 is an unknown quantity at this point
Re: Bumper Update
By square I mean rectangular.
31 wide 28 long, though we're working now with more of a trapezoid shape, with angled sides. I'm not entirely sure why this design wouldn't fit onto the batter. Maybe it'd get stuck on the large, angled surface?
Unread 11-02-2016, 09:16
FRC #1559
Re: Bumper Update
double check the space between the dividers on the batter. I did not find a dimension, but they look to be 2'6" close to the tower - which will fit a 28" wide robot (assuming bumpers higher than divider) up against the tower, but not a 31". If you dont plan on scaling the tower, it may not matter.
