Go to Post Finally, they're getting rid of the spotlights. I'm sick of seeing ridiculous inside jokes up there. - Karthik [more]
Unread 29-01-2016, 11:26
centralrobotics's Avatar
centralrobotics centralrobotics is offline
FRC #4054
centralrobotics is an unknown quantity at this point
Camera mounted on robot
Can anyone tell me what the best camera to use would be, and how we could stream that to our computer during competition? Thanks!
Unread 29-01-2016, 11:36
swaxman12345's Avatar
swaxman12345 swaxman12345 is offline
Team Member
AKA: Sasha Waxman
FRC #2512 (Daredevils)
Team Role: CAD
Rookie Year: 2015
swaxman12345 is an unknown quantity at this point
Re: Camera mounted on robot
I'm pretty sure it has to be hooked up to whatever signal you're using to control the robot; I don't think you can use a separate connection. We use a wifi router (I'm not sure if that's required or not). As to which camera to use, perhaps a gopro or something similar in size? I don't know any specifics.
Beware the Kraken, Jebediah. - Bill Kerman
Unread 29-01-2016, 12:01
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
Not enough detail is given, is this camera for the game or just recording?
If it's for the game any regular USB web camera will do, just plug it into the RIO and make sure that it's coded properly to accept and transmit the video feed.
Keep in mind there are bandwidth limitations so framerate, frame size, and even color may be variables that you need to tweak to stay under that limit.
College sux yo
Unread 29-01-2016, 12:35
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
These cameras work nicely for use in match. They have to be powered by the bot (use the Voltage Regulator Module) and are connected via Ethernet to your robot's radio/bridge. Don't worry about a high quality, you'll have to turn it down to 320x200 or something in that range during a real match anyways.
http://www.axis.com/us/en/products/axis-m10-series
For just recording during the match and NOT using the camera for vision during the match or as part your code, then a GoPro works very nicely.
I kind of know programming
