Go to Post Why is it OK to be "elitist" when we select people to be on a team to hit rocks with sticks, but not OK when we try to reach the special group of students that embody the intellectual capital that will define the future of this country? - dlavery [more]
Unread 29-01-2016, 12:15
jlee0119 jlee0119 is offline
FRC #2849 (Ursa Major)
jlee0119 can only hope to improve
Pneumatic system
Hello all,
I'm going to cut straight to the question. Is it legal to have a pneumatic system on the robot(compressor, solenoid, etc...) WITHOUT a air tank in the system?
Thanks
Unread 29-01-2016, 12:23
ArtemusMaximus's Avatar
ArtemusMaximus ArtemusMaximus is offline
Enginerd
FTC #11722
ArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to allArtemusMaximus is a name known to all
Re: Pneumatic system
Originally Posted by jlee0119 View Post
Hello all,
Thanks
I believe so. Though, the question is "Why would you want system without air tank?"
Unread 29-01-2016, 12:24
Type's Avatar
Type Type is offline
FRC #3452 (GreengineerZ)
Rookie Year: 2016
Type is an unknown quantity at this point
All the diagrams on the game manual appear that you have to have a tank. I'm not sure why you wouldn't want one. You would have very low pressure going to your pneumatic systems, and whenever you used something, you would be using the compressor. That would kill your battery quickly. If you only want to use pneumatics once, it would probably be a better idea to have an off board compressor, and have a tank to store it in.
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Whether or not it's legal, it doesn't make sense. In practically all cases, the solenoids use air faster than the compressor can generate it. Without a tank, the compressor would have to come on every time you actuate something, and run until it makes enough air to do the work.
That said, unless there's something in the rules that says that it is required, it is not.
Unread 29-01-2016, 12:41
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I see nothing to say it is illegal but you could theoretically store air in the pneumatic tubing between the compressor and the solenoid. That's quite a bit of tubing though.
461 Westside Boiler Invasion
45 Technokats
