Go to Post After all FIRST & CD are both places to learn everything. - popnbrown [more]
Unread 29-01-2016, 11:56
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Mounting encoders to WCP SS Gearbox
Just wondering if anyone has any experience mounting an encoder to the WCP SS gearbox. I'd like to see if there is an elegant solution to this before we start modifying anything.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 29-01-2016, 12:39
Joseph Smith's Avatar
Joseph Smith Joseph Smith is offline
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
Re: Mounting encoders to WCP SS Gearbox
We elegantly modified ours.
Edit: We drilled and tapped holes to mount an encoder mount pad (http://www.andymark.com/spacer-p/am-0208.htm) to the motor mount side of the gearbox. Seems to fit nicely without compromising the gearbox function at all.
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 29-01-2016, 12:40
Ty Tremblay's Avatar
Robotics Engineer
FRC #0319 (Big Bad Bob)
Good job Joe. How about sharing what you did?
Unread 29-01-2016, 12:49
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Mounting US Digital S4s or Grayhills are really easy. You can just press the encoder into the hole that already exists in the gearbox shaft, maybe with a little superglue, and then just use the wiring to stop it from rotating.
Mounting the USDigital E4Ps is harder however. When we did it in 2014, we 3d printed a mount for the encoder that clipped to the gearbox, and then glued a piece of shaft to the axle to use for driving the disk. However, I've seen many times where the E4Ps get assembled incorrectly, so I would highly suggest getting USDigital S4s or Grayhills. S4s are harder to buy, however Grayhill 63Rs can be purchases straight through Digikey here http://www.digikey.com/product-searc...256&vendor=136
Team 4488 - Mentor 2013-2016
Unread 31-01-2016, 08:40
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
This works with the SS & CTR magnetic encoder. (STL print file)
http://www.chiefdelphi.com/forums/sh...21&postcount=9
Unread 31-01-2016, 21:38
JABianchi's Avatar
JABianchi JABianchi is offline
FRC #1660 (Harlem Knights)
JABianchi is on a distinguished road
We're trying out the new AndyMark CIMcoders this year.
This makes the CIM output shaft just long enough to fit the pinion gear on, but very difficult to add a retaining clip. We sawed the pinion in half and it works fine.
Unread 31-01-2016, 22:27
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
Yup, in 2015 we used the WCP SS gearboxes and mounted Grayhill encoders with some zip ties and wire. Super simple. not elegant, but it stayed in and did the job.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
