Go to Post The FIRST family is incredible. - Libby Ritchie [more]
Unread 30-03-2003, 16:05
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
As mentioned previously, the ones in the kit are Helical gears. Are these the ones you are talking about or did you use bevel gears for something else?
Anyways, if you are talking about the helicals, I can tell you that we used them this year without any problems whatsoever. The key is to make sure you have spacers that are the correct size inside the gearbox and to make sure the shaft can't "walk" out of the gearbox. Here's some pics of our 'bot, which uses both the Chips and the Drills driving the gearboxes provided by FIRST:
http://www.cogsquad.org/image.php?id=34
http://www.chiefdelphi.com/forums/pi...gle&picid=4614
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
replacement gears joni_m Technical Discussion 1 22-01-2002 18:01
Are gears really this expensive? Anton Abaya Technical Discussion 2 13-01-2002 22:23
