Go to Post Part of being an effective leader is knowing your own personal limits. - artdutra04 [more]
Unread 29-01-2016, 13:06
Dalas Dalas is offline
Design Lead
FRC #4585 (Husky Robotics)
Team Role: Driver
Dalas is an unknown quantity at this point
FIRST Choice SENSOR BOARD (ACCELEROMETER & GYRO)
This is my first thread, so bear with me and let me know if I break any unspoken conventions.
We are a fairly inexperienced team, and just got the SENSOR BOARD (ACCELEROMETER & GYRO) from FIRST Choice (http://firstchoicebyandymark.com/fc16-000). Could we get some advice on connecting and using the sensor board to drive straight? Ideally we could easily disable this function while driving over terrain, getting in a pushing match, etc. We are programming in Java and have an 4-CIM 4-miniCim mechanum wheel drive which we are currently controlling using the RobotDrive class's mecanumDrive_Cartesian method. We are using 8 Talon SR motor controllers with PWM Y-splitters. No comments on the choice of drive train please, just programming/wiring advice.
Thanks in advance!
Unread 29-01-2016, 13:18
Poseidon5817's Avatar
Poseidon5817 Poseidon5817 is offline
"Cool" Squad
AKA: Mitchel Stokes
FRC #5817 (Uni-Rex)
Poseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud ofPoseidon5817 has much to be proud of
Re: FIRST Choice SENSOR BOARD (ACCELEROMETER & GYRO)
We are a fairly inexperienced team, and just got the SENSOR BOARD (ACCELEROMETER & GYRO) from FIRST Choice (http://firstchoicebyandymark.com/fc16-000). Could we get some advice on connecting and using the sensor board to drive straight? Ideally we could easily disable this function while driving over terrain, getting in a pushing match, etc. We are programming in Java and have an 8-CIM mechanum wheel drive which we are currently controlling using the RobotDrive class's mecanumDrive_Cartesian method. No comments on the choice of drive train please, just programming/wiring advice.
Thanks in advance!
I know that you said you didn't want any comments on drive train choice, but you are only allowed 6 CIMs on a robot. You're going to have to go down to one motor per mecanum wheel or you won't be legal.
My FRC History:
2014 - Team 1671: Central Valley Regional Finalist and Chairman's Award Winner, Sacramento Regional Finalist, Archimedes Quarterfinalist
2015 - Team 1671: Central Valley Regional Semifinalist, Sacramento Regional Semifinalist and Chairman's Award Winner, Newton Winner, Einstein Winner
2016 - Team 5817: Central Valley Regional Finalist and Rookie All-Star, Orange County Regional Quarterfinalist and Rookie All-Star, Newton Division
2017 - Team 5817: Return of the bench grinder
Unread 29-01-2016, 13:37
Design Lead
Team Role: Driver
Sorry, I should have been more clear - we are using 4 CIMS and 4 miniCIMS. The original post has been edited to specify this.
Unread 29-01-2016, 14:07
What motor controllers are you using?
Unread 29-01-2016, 14:20
Design Lead
Team Role: Driver
We are using 8 Talon SR motor controllers. Original post edited.
Unread 29-01-2016, 14:31
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Have you looked at the tutorial?
http://files.andymark.com/ADI_FRC_Gy...rd_LV_2016.pdf
In theory, what you want to do is: Determine a desired gyro angle, and adjust power to the wheels as you drive to keep you pointing in that direction. There may be functions in the libraries that do most of that for you.
Unread 29-01-2016, 15:02
Design Lead
Team Role: Driver
Originally Posted by rich2202 View Post
Unfortunately that tutorial is for labview, which I have no experience with. We are using Java. I've been looking at the ADIS16448_IMU class at https://github.com/juchong/ADIS16448...16448_IMU.java , so I know how to get basic data from the sensor board. Given time I'm sure I could figure out some way to adjust motor output by comparing joystick input and sensor data. We're very busy though, so if there's a standard way of implementing this I'd be interested in knowing how it works.
Unread 29-01-2016, 15:35
OK:
- mecanum drivetrain
- no encoders
- using TalonSR
- want to use gyro to drive straight
Does this help?
Unread 29-01-2016, 15:49
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Here is another thread with a lot of the same questions/answers.
http://www.chiefdelphi.com/forums/sh...php?&p=1531890
Ask if you need more.
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
