Go to Post When we got it tuned to the point where we were (reasonably) confident it wouldn't slam into Dave's ankle, we quit for the evening. - Kevin Watson [more]
Unread 29-01-2016, 15:38
RacerX's Avatar
RacerX RacerX is offline
FRC #0948 (NRG948)
RacerX is on a distinguished road
Re: Andymark rhino drivetrain discussion
If it becomes an issue with the tread being pushed off the wheels with side load, which I doubt will happen with a properly tensioned belt, can the Rhino Teams add a plate to the sides of the wheels, slightly larger than the wheel, so it overlaps the white part of the belt?
This would be similar to the other belt pulleys that are used.
In addition to the plates, perhaps a mechanism to deflate pneumatic tires could also be added?
Unread 29-01-2016, 16:34
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Not comparable. Treads coming off a tread drive (ANY tread drive) from base to base interaction is a chassis that cannot withstand the rigors of FRC. Poking holes in pneumatic wheels is damaging and deliberate contact inside the frame perimeter.
Causing a team with under inflated tires to pinchflat under heavy defense is the parallel.
I'd be very interested in seeing the results of the test Mike has outlined.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 29-01-2016, 16:59
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by Jon K. View Post
I would be more worried about weakening the aluminum at the weld. We at AndyMark did extensive hit tests on these turnbuckles at full speed with a fully weighted chassis into a piece of diamond plate that was backed by a full pallet of roller chain, so it had no where to go. We are working on putting up some videos of our testing so that the community can see what we have done to test the modules before we were comfortable selling them.
The eyelets in the turnbuckles are aluminum? What alloy?
They appear as zinc-plated steel eyelets with an aluminum body, but you would of course know better!
Posting test videos would be a great way to address concerns of their robustness given the long the somewhat sordid history of treads in FRC drives. I look forward to seeing them!
Unread 08-02-2016, 12:07
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Any updates on videos or turnbuckle materials? I am still quite curious.
Unread 08-02-2016, 12:19
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
https://www.youtube.com/watch?v=v8oMG5NQS0o
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 08-02-2016, 18:53
Jon K. Jon K. is offline
n.e.r.d #6
Jon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond reputeJon K. has a reputation beyond repute
James,
Sorry I missed your previous question. I am not sure what I was thinking when I was talking about weakening the aluminum at the weld. The outer body is aluminum, but the threaded rod and by extension the eyelets are steel. We did do some more testing with the chassis regarding t-bone tests, and have that up on the AndyMark YouTube channel, as posted above. I know we had some problems getting the videos to merge properly to post the testing to the channel, but I will see what we can do about getting the tests duplicated or uploaded individually. I know given the discussions happening here that we may have more testing videos once the pulleys have been updated.
Alumnus of FLL 2000 ~ Alumnus of FRC173 2002-2005 ~ Mentor of FRC173 2006-2007 ~ Mentor of FRC 3780 2014
FIRST Volunteer since 2003
Manufacturing Manager
AndyMark, Inc.
http://www.andymark.com
Unread 09-02-2016, 15:20
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
James,
Cool, thanks!
