Go to Post FIRST has a 365 day season (366 on leap years)... - Adam Richards [more]
Unread 01-29-2016, 07:21 PM
simon1636 simon1636 is offline
FRC #4501
simon1636 is an unknown quantity at this point
Throttle Trouble
Hi! I am trying to get our shooter to work with two talons by moving the throttle on the Attack 3 joystick upwards. My code looks right, but is not doing anything. Can any of you guys see anything? Any help would be greatly appreciated! Thanks!
/* Copyright (c) FIRST 2008. All Rights Reserved.                             */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.SimpleRobot;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the SimpleRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class RobotTemplate extends SimpleRobot {
     * This function is called once each time the robot enters autonomous mode.
    Jaguar lTalon,rTalon;
    Joystick throttle;
    RobotDrive driveTrain;
    public void autonomous() {
     * This function is called once each time the robot enters operator control.
    public void robotInit(){
        lTalon=new Jaguar(1);
        rTalon=new Jaguar(2);
        throttle=new Joystick(0);
        driveTrain=new RobotDrive(lTalon,rTalon);
    public void operatorControl() {
        while(isOperatorControl() &&isEnabled()){
            driveTrain.arcadeDrive(throttle.getAxis(Joystick.AxisType.kZ), 0);
     * This function is called once each time the robot enters test mode.
Unread 01-29-2016, 08:17 PM
TimTheGreat's Avatar
TimTheGreat TimTheGreat is offline
ArchdukeTim
FRC #1418 (Vae Victis)
TimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura aboutTimTheGreat has a spectacular aura about
Re: Throttle Trouble
Are you trying to use the driveTrain on a shooter mechanism? If so, probably not the best way to do it.
Try using throttle.getZ().
Also, since you have a simple robot you should use
#In the operatorControl method
lTalon.set(throttle.getZ())
rTalon.set(-throttle.getZ())
There are two ways of constructing a software design: One way is to make it so simple that there are obviously no deficiencies, and the other way is to make it so complicated that there are no obvious deficiencies. The first method is far more difficult.
2012 - Gracious Professionalism - Greater DC
2014 - Regional Finalist - Virginia | Industrial Design - Virginia | Regional Finalist - Greater DC
2015 - Innovation in Control - Greater DC
2016 - District Event Winner - VAHAY | Innovation in Control - VAHAY | District Event Winner - MDBET | Industrial Design - MDBET | District Champion - CHCMP | Innovation in Control - CHCMP
Unread 01-30-2016, 05:59 PM
FRC #4501
It still does not seem to be working. Do you see anything else weird? I did all that you said.
/* the project.                                                               */
 * directory.
    Joystick throttle;
           lTalon.set(throttle.getZ());
           rTalon.set(-throttle.getZ());
Unread 02-01-2016, 02:47 AM
mmaunu's Avatar
mmaunu mmaunu is offline
FRC #2485 (W.A.R. Lords)
mmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the roughmmaunu is a jewel in the rough
Your class needs to extend SampleRobot, not SimpleRobot. I'm surprised that even compiles as SimpleRobot is not part of the Java API anymore. Give that a try?
2014 Las Vegas (Winners with 987, 2478; Excellence in Engineering)
2014 San Diego (Finalists with 987, 3250; Quality Award)
2013 Inland Empire (Winners with 1538, 968; Excellence in Engineering Award)
2013 San Diego (Finalists with 2984, 4322; Creativity Award)
2012 Las Vegas (Finalists with 2034, 3187; Quality Award)
