Re: How many CIMs in your drivetrain?
CIM FR801 001, AM802 001A @ 12.00 volts oz-in=45.6, Nm=0.322, rpm=86.7, amps=20, watts out = 155.3, watts heat is 84.7 and eff% = 64.7 So I'm seeing the three CIMs each drawing 20 amps at 12 volts: 465.9 watts output mechanical power 254.1 watts waste heat vs these two choices that Ether's calculations from before. one CIM drawing 60 amps at 12 volts: 332 watts output mechanical power 388 watts waste heat two CIMs each drawing 30 amps at 12 volts: 447 watts output mechanical power 273 watts waste heat So not as much of a gain in efficiency improvement as I had hoped, but the package is still capable of much more. |
