Go to Post it would be a sign you do too much robotics when you find toolpaths sexy. - Aren_Hill [more]
Unread 29-01-2016, 22:58
B_Rad or B_Mad B_Rad or B_Mad is offline
FRC #2977
B_Rad or B_Mad is an unknown quantity at this point
FRC 2977 Shooter Prototype
Team 2977's Shooter Prototype. It is very consistent just have to figure out the how to line it up correctly
http://youtu.be/tyZFmCqT54k
Unread 29-01-2016, 23:07
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: FRC 2977 Shooter Prototype
Any plans on how to get and control " the right motor speed"?
It does seem to be fairly consistent.
Unread 29-01-2016, 23:08
NinjaMunkeeNao's Avatar
NinjaMunkeeNao NinjaMunkeeNao is offline
i'll literally do whatever :D
AKA: Naomi Christina Alexander
FRC #2395 (The Ninja Munkees)
Rookie Year: 2016
NinjaMunkeeNao is an unknown quantity at this point
Great job guys! That looks awesome!
Unread 29-01-2016, 23:13
FRC #2977
We plan on adjusting the where the motors are placed and then finding a consistent "go to" spot near the tower so we can always make the shot. We may also be using sensors to find this "go to" spot
Unread 30-01-2016, 00:33
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
So, my team went for a motorized kick in 2014, and really regretted it.
Here's our reveal video from that year.
It's a different game, and the game piece is much lighter this year, so you might not have the same problems, but here are some points that we had problems with that you might want to consider:
  • A kicker usually means you are shooting from down low. If you're going for distance, that means your shots can be easily blocked. (you don't seem to have this problem if you're only shooting from the batter.
  • Different battery voltages meant the kick had varying strength. the nature of the mechanism prevents you from using closed loop control to get a consistant speed as well.
  • The ball can not be held while you are kicking it. even having a holding mechanism which releases at just the right time still opens you up to a defensive bump in the critical moment.
  • The above two points also means it is virtually impossible to shoot while driving. There's a significant delay between when you get to a point and when you actually shoot. this opens you up to defense.
So that's some stuff that we had trouble with in 2014, most of it, I think, applies this year as well so try and see if you can avoid those problems somehow.
Good luck!
-Leav
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 30-01-2016, 00:43
And just as a note, from experience: If you always shoot from the same place, and it's NOT a safe zone, expect to not be able to get there easily. Somebody will be more than happy to park there and keep you from getting to that spot, or hit you every time you look like you're heading there.
Unread 30-01-2016, 01:37
vanjor18 vanjor18 is offline
FRC #2977
vanjor18 is an unknown quantity at this point
We will hopefully be able to shoot at more than one high goal in the end, but we have a lot more planned out and in development.
I think that rhino tracks should be able to help us hold our ground against most pushing (at least from the side), but we definitely have to make sure that the ball is safely secured so it doesn't fall out.
Unread 30-01-2016, 10:07
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Nifty, kind of a cleaner version of what Team Cockamamie did in Ri3D.
You guys were the rank 1 winners of Israel, sure it had issues at championships but I would call your teams first ever Blue Banner not a robot you should really regret anything on, don't be so hard on yourselves
The game piece also seems like it is more reliable, what I mean is, there is no adjusting for inflation, there is no zipper meaning no vastly different location on the ball in terms of flexibility and the game piece is smaller, giving you a lot more control over it.
[*]Different battery voltages meant the kick had varying strength. the nature of the mechanism prevents you from using closed loop control to get a consistant speed as well.
The kicker they are going for is going to hopefully have a lot less current draw then what we had to deal with in 2014 to get a ball going, but this point will also be true for a wheeled shooter, which a lot of people are going for.
[*]The above two points also means it is virtually impossible to shoot while driving. There's a significant delay between when you get to a point and when you actually shoot. this opens you up to defense.
Agree to disagree, in 2014 we had a puncher as opposed to a kicker which also shot "low" (A moderately tall robot in front of us could easily block us), needed to hold the ball until right before we shot it, and we could shoot while driving, well being pushed by a defender
I think what Eric was saying or trying to get you to think about more was, If you have a sweet spot that is unprotected (like being up against the fender in 2012) defenders don't need to push you to stop your shot, they just need to get in front of you to stop you from being able to park there. Now if you can make your shot from within one robot length of your sweet spot, your golden.
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 30-01-2016, 10:55
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
I remember your robot from the Galileo division in 2014. When I was pre-scouting before champs I remember watching your teams reveal video and I loved the motorized kick- it was definitely an interesting concept and seemed to work well for you guys.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
