Go to Post You can lay out all the disclaimers that you want, but the bottom line is you are representing your team. - Karthik [more]
Unread 28-01-2016, 13:46
MoistRobot's Avatar
MoistRobot MoistRobot is offline
AKA: Jon Charboneau
FRC #0832 (OSCAR)
MoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of lightMoistRobot is a glorious beacon of light
Re: Dynamic Brake/Coast Modes?
I know we had dynamic brake/coast in our drive train on the 2012 robot, however I believe we used a spike to control the state on the jaguar jumper pins.
Don't believe it was even questioned during inspection at 2 regionals.
Unread 28-01-2016, 14:05
Volunteer, WPILib Contributor
no team (Waiting for 2021)
It had been assumed to be legal, including I'm pretty sure Al had used it and suggested it in the past. But if they found a hardware issue where high current could end up running though a legally allowed to be 28 AWG wire, it's absolutely the right call to make it illegal. Thats a good way to start a fire really easily.
Team 4488 - Mentor 2013-2016
Unread 28-01-2016, 17:39
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
As promised previously, here's the Q&A so that when someone reads this in 2020 they can see the content:
Originally Posted by Q646
  • Q. In this post: http://www.chiefdelphi.com/forums/sh...81&postcount=3 and following, it is suggested that the brake/coast pin of a PWM-controlled motor controller may be wired to a control signal from the RoboRIO's DIO port. I read this as a violation of R68, and as a modification beyond the wording of R66, especially bullet I. Others there see it as legal. Is this practice permitted? If allowed, I suggest providing clarification in the rules as to how to wire this safely.
  • A. You are correct, this practice is a violation of R68. We acknowledge that this has been a common practice, and we will review this with Inspectors.
As for a simple way to do this safely (but not currently legally), an optoisolator could be used to act as a virtual jumper. Assuming the outputs of the isolator can handle the current that passes through the jumpers, this should only need a ballast resistor for the LEDs to be enough. If more current is needed, a few transistors and resistors would be necessary to supplement. One could even do the double isolation and use a totally COTS relay module. Repeat: this would be safe, but not (currently) FRC legal.
Unread 28-01-2016, 18:23
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
Virtually no current passes through the brake/coast jumper.
On the Jaguar (I cann't speak for the design of others, but I can for Jag) the current involved is that in charging the MCU's GPIO input. The GPIO input uses an internal (to the MCU) pull up which is on the order of 50 kohms. The isolator would only have to pull the input below VIL.
Note that this opto isolator, like the one on Jaguar's PWM input, is inverting.
Unread 28-01-2016, 21:20
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
If there is virtually no current, couldn't you just move the resistor and output tap to the ground (emitter) side and re-invert passively?
In any case, I was thinking of using the phototransistor side directly as a switch between the center pin and the brake/coast pins. To do this, you would only need to know whether the jumper pulled the B/C pins up or down.
Unread 29-01-2016, 07:27
I have received reports from independent testing that jumper current is well under 10 ma in all controllers but it does vary from manufacturer to manufacturer.
Unread 29-01-2016, 08:04
GeeTwo's Avatar
Technical Director
AKA: Gus Michel II
Thanks, Al. I'll file this one away as a post-season control project.
Unread 29-01-2016, 23:55
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Originally Posted by seg9585 View Post
...I have not used CAN control on the Talons before, so I wasn't sure if the Talons could be programmed with this functionality...
As mentioned by GeeTwo, CAN Talon SRX supports this and is in the Talon SRX Software Reference Manual.
Quick example here also...
https://github.com/CrossTheRoadElec/...bot/Robot.java
