Go to Post FIRST is not really located in Manchester NH but with each student and mentor involved - UCGL_Guy [more]
Unread 30-01-2016, 13:18
thomasmcdonald thomasmcdonald is offline
FRC #2587
thomasmcdonald is an unknown quantity at this point
PWM Talon SR Problem
Whenever we try to enable the electrical board (roboRIO) using the driver station, we get the following error from the driver station console:
ERROR Unhandled exception: java.lang.NullPointerException at
[org.discobots.stronghold.subsystems.DriveTrainSubsystem.tankDriveUnramped(DriveTrainSubsystem.java:133),
org.discobots.stronghold.subsystems.DriveTrainSubsystem.tankDriveRamp(DriveTrainSubsystem.java:76),
org.discobots.stronghold.commands.drive.TankDriveCommand.execute(TankDriveCommand.java:24),
edu.wpi.first.wpilibj.command.Command.run(Command.java:240),
edu.wpi.first.wpilibj.command.Scheduler.run(Scheduler.java:222),
org.discobots.stronghold.Robot.teleopPeriodic(Robot.java:139),
edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:143),
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)]
WARNING: Robots don't quit!
I have tried it with CAN and using the CANTalon class with TalonSRX motor controllers and the code works like a charm and it stays enabled. I am now trying to use the same code, but changing the ports to PWM ports and we are now using TalonSR motor controllers (Which do not have a class in the 2016 libraries). I have changed the motor controller types in the code to Jaguars, Victor, Talon, TalonSRX, and Victor SP, but I am still getting the same error as soon as I enable using the driver station. We also get the same error when there's not anything physically attached to the ports, but they are still referred to in the code.
When I comment out anything referring to the PWM motor controllers, I do not get an error.
Any suggestions on what the problem might be?
Thanks!
Unread 30-01-2016, 13:22
jajabinx124's Avatar
jajabinx124 jajabinx124 is offline
Team 2052 Alumnus
AKA: Kshitij Wavre
jajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond reputejajabinx124 has a reputation beyond repute
Re: PWM Talon SR Problem
Post your code. Null pointer errors occur in code. We cannot guess what is causing the null pointer exception without looking at the code.
FRC Volunteer CSA (MRI off-season event, 2017 Lake Superior Regional, 2017 10,000 Lakes Regional) 2016 - Present
FRC 2052 KnightKrawler (Team Captain, Strategist, Scouting, Programming) 2013 - 2016
1 Division Win & Einstein Appearance
3 Division Quarter-Finalists
1 Regional Chairman's Award
5 Regional Wins, 3 Regional Finalists
3 MN State Championship Wins, 1 MN State Championship Finalist
Thanks to all our alliance partners who krawled with us: 41, 70, 225, 525, 1595, 2054, 2062, 2122, 2175, 2227, 2472, 2526, 2883, 2990, 3018, 3244, 3276, 3310, 3313, 3360, 3538, 3692, 4011, 4198, 4536, 4607, 4778, 5172, 5690
Unread 30-01-2016, 14:37
FRC #2587
Drive train subsystem
package org.discobots.stronghold.subsystems;
import org.discobots.stronghold.HW;
import org.discobots.stronghold.commands.drive.ArcadeDriveCommand;
import org.discobots.stronghold.commands.drive.TankDriveCommand;
import edu.wpi.first.wpilibj.CANTalon;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.TalonSRX;
import edu.wpi.first.wpilibj.command.Subsystem;
public class DriveTrainSubsystem extends Subsystem {
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
	/* Motors */
	//TalonSRX frontRight, frontMiddleRight, backMiddleRight, backRight, frontLeft,frontMiddleLeft, backMiddleLeft,
	//backLeft;
	Talon mRight, mLeft;
	RobotDrive robotDrive;
	static final double CONSTANT_RAMP_LIMIT = 0.1; // ramping
	// 0.05 = 4/10 seconds to full, 0.1 = 2/10 seconds to full
	boolean allowRamped = false;
	private double prevLeft = 0, prevRight = 0;
	private double prevY = 0, prevX = 0, prevR;
	int choice=0;
	static double kSpeedScaling = 1.0;
	public DriveTrainSubsystem() {
	choice =-1; //default tank drive if no choice chosen (prevents null pointer exception)
	public DriveTrainSubsystem(int choose) {
		choice = choose;
		switch(choose)
		case 1: new TankDriveCommand();
		case 2: new ArcadeDriveCommand();
		default: new TankDriveCommand();
		/* Motors */
		mRight = new Talon(HW.motorRight);
		mLeft = new Talon(HW.motorLeft);
		/* Sensors */
		/* RobotDrive */
		robotDrive = new RobotDrive(mLeft, mRight);
		//robotDrive = new RobotDrive(mRight, mRight);
	public void setRamped(boolean a) {
		this.allowRamped = a;
	public boolean getRamped() {
		return this.allowRamped;
	public void tankDriveRamp(double leftStick, double rightStick) {
		if (!allowRamped) {
			tankDriveUnramped(leftStick, rightStick);
			return;
		double left = leftStick, right = -rightStick;
		if (left - prevLeft > CONSTANT_RAMP_LIMIT) {
			left = prevLeft + CONSTANT_RAMP_LIMIT;
		} else if (prevLeft - left > CONSTANT_RAMP_LIMIT) {
			left = prevLeft - CONSTANT_RAMP_LIMIT;
		if (right - prevRight > CONSTANT_RAMP_LIMIT) {
			right = prevRight + CONSTANT_RAMP_LIMIT;
		} else if (prevRight - right > CONSTANT_RAMP_LIMIT) {
			right = prevRight - CONSTANT_RAMP_LIMIT;
		prevLeft = left;
		prevRight = right;
		robotDrive.tankDrive(left * kSpeedScaling, right * kSpeedScaling);
	public void arcadeDriveRamp(double iy, double ix) {
		if (!allowRamped) {
			arcadeDriveUnramped(iy, ix);
			return;
		double ox = ix, oy = -iy;
		if (oy - prevY > CONSTANT_RAMP_LIMIT) {
			oy = prevY + CONSTANT_RAMP_LIMIT;
		} else if (prevY - oy > CONSTANT_RAMP_LIMIT) {
			oy = prevY - CONSTANT_RAMP_LIMIT;
		if (ox - prevX > CONSTANT_RAMP_LIMIT) {
			ox = prevX + CONSTANT_RAMP_LIMIT;
		} else if (prevX - ox > CONSTANT_RAMP_LIMIT) {
			ox = prevX - CONSTANT_RAMP_LIMIT;
		prevX = ox;
		prevY = oy;
		robotDrive.arcadeDrive(ox * kSpeedScaling, oy * kSpeedScaling);
		// RobotDrive is dumb arcadeDrive so parameters are switched
	public void tankDriveUnramped(double leftStick, double rightStick) {
		prevLeft = 0;
		prevRight = 0;
		prevX = 0;
		prevY = 0;
		prevR = 0;
		robotDrive.tankDrive(leftStick * kSpeedScaling, -rightStick
				* kSpeedScaling);
	public void arcadeDriveUnramped(double y, double x) {
		prevLeft = 0;
		prevRight = 0;
		prevX = 0;
		prevY = 0;
		prevR = 0;
		robotDrive.arcadeDrive(x * kSpeedScaling, -y * kSpeedScaling);
		// robotdrive is dumb arcadeDrive so params are switched
	public void initDefaultCommand() {
		if (!(choice>=0))
		setDefaultCommand(new TankDriveCommand());
	public double getSpeedScaling() {
		return kSpeedScaling;
	public void setSpeedScaling(double a) {
		kSpeedScaling = a;
HW (Hardware)
package org.discobots.stronghold;
 * The RobotMap is a mapping from the ports sensors and actuators are wired into
 * to a variable name. This provides flexibility changing wiring, makes checking
 * the wiring easier and significantly reduces the number of magic numbers
 * floating around.
public class HW {
    // For example to map the left and right motors, you could define the
    // following variables to use with your drivetrain subsystem.
    // public static int leftMotor = 1;
    // public static int rightMotor = 2;
    // If you are using multiple modules, make sure to define both the port
    // number and the module. For example you with a rangefinder:
    // public static int rangefinderPort = 1;
    // public static int rangefinderModule = 1;
	/* CAN */// Check roboRio web interface for these values
	/* PWM */
	public final static int motorRight = 0;
	public final static int motorLeft = 1;
	/* Pneumatics */
Robot
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import java.util.concurrent.TimeUnit;
import org.discobots.stronghold.commands.AutonomousCommand;
//import org.discobots.stronghold.commands.ExampleCommand;
import org.discobots.stronghold.subsystems.DriveTrainSubsystem;
//import org.discobots.stronghold.subsystems.ExampleSubsystem;
import edu.wpi.first.wpilibj.smartdashboard.SendableChooser;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
 * The VM is configured to automatically run this class, and to call the
 * functions corresponding to each mode, as described in the IterativeRobot
 * documentation. If you change the name of this class or the package after
 * creating this project, you must also update the manifest file in the resource
 * directory.
public class Robot extends IterativeRobot {
	public static OI oi;
	public static double totalTime;
	public static long TeleopStartTime;
	public static long loopExecutionTime = 0;
	public static DriveTrainSubsystem driveTrainSub;
    Command autonomousCommand,driveCommand;
    SendableChooser chooser, autonChooser;
     * This function is run when the robot is first started up and should be
     * used for any initialization code.
    public void robotInit() {
		oi = new OI();
		/* Subsystems */
		driveTrainSub = new DriveTrainSubsystem();
		autonChooser = new SendableChooser();
		autonChooser.addDefault("Auton1", new AutonomousCommand());
		autonChooser.addObject("Auton2", new AutonomousCommand());
		SmartDashboard.putData("Choose Auton", autonChooser);
		// dashboard init
		Dashboard.init();
		Dashboard.update();
     * This function is called once each time the robot enters Disabled mode.
     * You can use it to reset any subsystem information you want to clear when
	 * the robot is disabled.
    public void disabledInit(){
    	for (long stop=System.nanoTime()+TimeUnit.SECONDS.toNanos(1);stop>System.nanoTime();) { //rumbles upon disable for 1 second
			oi.setRumble(1);
	public void disabledPeriodic() {
		long start = System.currentTimeMillis();
		Scheduler.getInstance().run();
		Dashboard.update();
		long end = System.currentTimeMillis();
		loopExecutionTime = end - start;
	 * This autonomous (along with the chooser code above) shows how to select between different autonomous modes
	 * using the dashboard. The sendable chooser code works with the Java SmartDashboard. If you prefer the LabVIEW
	 * Dashboard, remove all of the chooser code and uncomment the getString code to get the auto name from the text box
	 * below the Gyro
	 * You can add additional auto modes by adding additional commands to the chooser code above (like the commented example)
	 * or additional comparisons to the switch structure below with additional strings & commands.
    public void autonomousInit() {
        autonomousCommand = (Command) autonChooser.getSelected();
		/* String autoSelected = SmartDashboard.getString("Auto Selector", "Default");
		switch(autoSelected) {
		case "My Auto":
			autonomousCommand = new MyAutoCommand();
			break;
		case "Default Auto":
		default:
			autonomousCommand = new ExampleCommand();
			break;
    	// schedule the autonomous command (example)
        if (autonomousCommand != null) autonomousCommand.start();
     * This function is called periodically during autonomous
    public void autonomousPeriodic() {
		Dashboard.update();
    public void teleopInit() {
		// This makes sure that the autonomous stops running when
        // teleop starts running. If you want the autonomous to
        // continue until interrupted by another command, remove
        // this line or comment it out.
        if (autonomousCommand != null) autonomousCommand.cancel();
        driveCommand = (Command) autonChooser.getSelected();
			oi.setRumble(1);
			TeleopStartTime = System.currentTimeMillis();
		if(driveCommand != null)
			driveCommand.start();
     * This function is called periodically during operator control
    public void teleopPeriodic() {
    	long start = System.currentTimeMillis(); //measures loop execution times
		Dashboard.update();
     * This function is called periodically during test mode
    public void testPeriodic() {
    	LiveWindow.run();
		Dashboard.update();
		totalTime = (double) ((System.currentTimeMillis() - TeleopStartTime)/1000);
Tank Drive Command
package org.discobots.stronghold.commands.drive;
import org.discobots.stronghold.Robot;
public class TankDriveCommand extends Command {
    public TankDriveCommand() {
        // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
    	requires(Robot.driveTrainSub);
    // Called just before this Command runs the first time
    protected void initialize() {
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
    	Robot.driveTrainSub.tankDriveRamp(Robot.oi.getRawAnalogStickALY(),Robot.oi.getRawAnalogStickARY());
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        return false;
    // Called once after isFinished returns true
    protected void end() {
    	Robot.driveTrainSub.tankDriveUnramped(0, 0);
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
    	end();
Thanks
Unread 31-01-2016, 18:17
codedr codedr is offline
FRC #0537
codedr will become famous soon enoughcodedr will become famous soon enough
In DriveTrainSubsystem class you have two constructors.
The one without the (int choose) argument is being called, and does not initialize robotDrive.
The one with (int choose) is not being called, and it is the one which init's robotDrive.
Unread 01-02-2016, 11:28
FRC #2587
Thanks! I found the error. I also had an error where I was creating a RobotDrive and put Talon objects as the parameters instead of PWM port numbers.
