Re: Robot Losing communication
thanks you very much for your fast responses. We just solved the issue. It seems like the computer we were using just need to be restarted and it worked fine. Not sure what went wrong but this seems to have fixed the problem
that is a good point. We are going through test this afternoon to see if we can find the problem. I will let you guys know if i find it.
Other people on the forums have reported connection issues with an Autodesk updater running on their system. If you have Autodesk installed, you may want to look into that.
Thanks for your help |
#7
Just for future reference, if you had provided the above info in response to the following question: You would have gotten your answer a day earlier ![]() Last edited by Ether : 31-01-2016 at 15:44. |
