Go to Post Totally agree on the fact that legal strategies are... legal. - Kevin Sevcik [more]
Unread 30-01-2016, 13:48
Mr_Moko's Avatar
Mr_Moko Mr_Moko is offline
[INSERT TITLE HERE]
AKA: Jaye
FRC #2729 (STORM Robotics)
Mr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond reputeMr_Moko has a reputation beyond repute
[Help Needed] Javascript Team Finder
Greetings Chief Delphi members!
I'm from from FRC 2729 Storm Robotics and I was wondering if someone could help with an issue that we're having with our Team Number Finder in JavaScript.
We can get one page of team numbers (500 numbers) off of any given page using The Blue Alliance api due to the fact that the HTTP request only executes on the last iteration of the for loop. The problem we are having is that when we try to get more than one page, the values become undefined.
If someone could look through the code and lend us a hand, that would be wonderful!
HTML
JavaScript
Thanks in advance for any help that is given!
Unread 30-01-2016, 13:53
jlmcmchl jlmcmchl is offline
FF - The Breakfast Company
AKA: Jordan McMichael
FRC #0027 (Team RUSH 27)
jlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud ofjlmcmchl has much to be proud of
Re: [Help Needed] Javascript Team Finder
Could you post a pastebin link, instead of quoting the code? It's really hard to read when you lose all the formatting.
Field reset: Kettering Kickoff ('13, '14), Kettering ('14, '15), Bedford ('14), Woodhaven ('16), Carver ('16), Einstein! ('16)
Referee: Bedford ('15), MARC ('15, '16), Kettering Kickoff ('15, '16), Kettering District (#1&2: '16), Troy ('16)
Unread 30-01-2016, 14:01
Mr_Moko's Avatar
[INSERT TITLE HERE]
AKA: Jaye
Replaced the Quotes with Hyperlinks to Pastebin.
Thanks for the advice! I'm not quite sure why I didn't think of that to begin with.
hardcopi hardcopi is offline
AKA: Rich Lester
FRC #2959 (The Robotarians)
hardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud ofhardcopi has much to be proud of
PHP Code:
document.getElementById("blank").innerHTML out
You appear to be overwriting the html of your div every iteration. Not sure in core javascript but in jquery it would be
PHP Code:
$('#blank').append(out);
A jsfiddle or pastbin would have been easier to debug though.
Unread 30-01-2016, 14:08
Mr_Moko's Avatar
[INSERT TITLE HERE]
AKA: Jaye
Originally Posted by hardcopi View Post
PHP Code:
PHP Code:
You posted just before I updated the post to have inks to Pastebin instead of quotes, thank your for opinion, I'll see if that helps!
Unread 30-01-2016, 14:34
Andrew Lobos Andrew Lobos is offline
FRC #0225 (TechFire)
Andrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the roughAndrew Lobos is a jewel in the rough
I think this JS will output what you expect (or something close): https://gist.github.com/4ndr3w/b924b0762416c0ba6885
In Chrome I get a big comma separated list of teams from 1 to something in the 6000's Note that the output has no guarantee of order since the HTTP requests are returning asynchronously.
hardcopi is right that it's probably better to append to the div. Your implementation will work since you are appending output to a global string and then writing the whole string back out to the div every loop, but it's not as clean
2012-2014: 225 Driver, Programmer & Co-Captain
2012-2014: FTC 4977 Driver, Programmer, & Team Captain
2011: 225 Operator & Programmer
2013: FRC: Springside-Chestnut Hill Winner (w/341 & 1495), Midknight Mayhem Winner (w/316, 369, & 869), Battle O' Baltimore Winner (w/1640, 2914 & 339), Duel on the Delaware Finalist (w/816 & 369), Ramp Riot Winner (w/341, 304, & 4637) FTC: PA State Finalist
2014: FRC: Springside-Chestnut Hill Winner (w/316 & 1495), Greater DC Winner (w/1731 & 4464), Midknight Mayhem Winner (w/25, 1626 & 329) FTC: PA State Champion
Unread 30-01-2016, 15:03
Mr_Moko's Avatar
[INSERT TITLE HERE]
AKA: Jaye
Thank you so much for your fix! If we use your version then I'll make sure to credit you for the fix.
I also agree with hardcopi and I'll possibly see what I can do about doing that, but for now, thanks again for now I believe we'll use your version.
Again, thank you!
