Go to Post FIRST involves school, parents, family etc etc....at least it does at our house! - MrForbes [more]
Unread 30-01-2016, 14:28
DGoldDragon28's Avatar
DGoldDragon28 DGoldDragon28 is offline
Programmer
FRC #1719 (The Umbrella Corporation)
Rookie Year: 2015
DGoldDragon28 is an unknown quantity at this point
[HELP NEEDED] IMAQdx USB camera settings
Using the LifeCam-3000, we are attempting to send a feed to the SmartDashboard. To do this, we grab from it using the IMAQdx methods of com.ni.vision.NIVision. We also need to alter the exposure of the camera, so added the line:
(new USBCamera("cam0")).setExposureManual(20);
The issue is that using both on the same camera leads to the following error:
ERROR Unhandled exception: VisionException [com.ni.vision.VisionException: IMAQdxError: -1074360310: Camera is already in use.] at
[com.ni.vision.NIVision._IMAQdxOpenCamera(Native Method),
com.ni.vision.NIVision.IMAQdxOpenCamera(NIVision.java:30334),
edu.wpi.first.wpilibj.vision.USBCamera.openCamera(USBCamera.java:72),
edu.wpi.first.wpilibj.vision.USBCamera.<init>(USBCamera.java:63),
org.usfirst.frc.team1719.robot.Robot.robotInit(Robot.java:78),
edu.wpi.first.wpilibj.IterativeRobot.startCompetition(IterativeRobot.java:72),
edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:241)]
WARNING: Robots don't quit!
There is no way that we found to use the IMAQdx session to change the exposure, so we ask here for aid.
Unread 30-01-2016, 14:36
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: [HELP NEEDED] IMAQdx USB camera settings
Usually when we get the "Robots don't quit" error, it is because we are initializing one sensor in more than one place. If that's not it, then we got nothing.
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 30-01-2016, 15:09
Programmer
Rookie Year: 2015
That's exactly what the problem is. We are trying to figure out a way to either convert an IMAQdx session ID to a USBCamera object or to set the exposure directly from the IMAQdx session ID.
Unread 30-01-2016, 16:26
legts legts is offline
Autonomous Queen
FRC #2399 (The Fighting Unicorns)
legts is an unknown quantity at this point
My team used this same kind of camera, our code is here: https://github.com/frc2399/2015-code...bot/Robot.java
The main camera code is on lines 95-98, take a look at it and ask me if you have any questions!
Programming Captain on team 2399 for the 2016 season.
Programmer on team 2399 The Fighting Unicorns since 2014!
Engineering Inspiration Award GPR 2015
Semi-finalist Buckeye 2015 (thanks 4269 and 1987!)
Unread 30-01-2016, 17:05
Programmer
Rookie Year: 2015
Thank you, but our problem lies with our images coming back overexposed, which the CameraServer can't fix. We need to change the webcam's settings.
Unread 30-01-2016, 17:17
Autonomous Queen
Could you possibly change the settings of the camera?
https://wpilib.screenstepslive.com/s...amera-settings
Unread 30-01-2016, 18:43
Programmer
Rookie Year: 2015
It's a LifeCam 3000, not an Axis. We don't have the Ethernet port space for an access with the new radio.
Unread 30-01-2016, 19:31
Autonomous Queen
After you make the cam0, make a new line and call the method to set the exposure there. Try messing around with higher and lower values to see what happens. Other then that, I'm not really sure what else there is I can do without seeing your code.
Unread 30-01-2016, 19:43
Programmer
Rookie Year: 2015
Thanks for the input, but we tried that. We are probably going to offload this process anyway, so I'll get back to you.
