Go to Post Keep in mind that words can be harsh and people do not forget what is said against them. Please, for your teammates sake, keep your egos in check and try to use some tact and consideration. - Andy Baker [more]
Unread 30-01-2016, 15:36
Sparta3648's Avatar
Sparta3648 Sparta3648 is offline
Mentor of team 3648
FRC #3648 (Sparta Robotica)
Sparta3648 is an unknown quantity at this point
Extension
Does the extension perimeter of 15 inches have any bearing on the maximum extension a robot has should it want to reach the high bar?
Unread 30-01-2016, 15:41
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Extension
No problem if you are only extending vertically from your ROBOT.
But if your ROBOT tips so that the FRAME PERIMETER is no longer parallel to the floor, it would be at a large risk of violating G18.
(since 2004)
Unread 30-01-2016, 15:45
laplacier's Avatar
laplacier laplacier is offline
FRC #1287 (Aluminum Assault)
Rookie Year: 2015
laplacier is an unknown quantity at this point
Re: Extension
Rule G17 states the following:
G17 ROBOT height, as measured when it’s resting normally on a flat floor, may not exceed 4 ft. 6 in.
during the MATCH, except during the final twenty (20) seconds of TELEOP where there is no height
limit when a ROBOT is fully contained by the opponent’s COURTYARD.
During the final 20 seconds of the match you are allowed unlimited height while in the same area of the field as the castle you are attempting to capture.
Unread 30-01-2016, 15:46
IronicDeadBird's Avatar
IronicDeadBird IronicDeadBird is offline
Theory Crafting Fo days...
AKA: Charles Ives "M" Waldo IV
FRC #1339 (Angelbots)
Team Role: Tactician
IronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond reputeIronicDeadBird has a reputation beyond repute
Re: Extension
The frame perimeter is a barrier that extends vertically. So while within your perimeter you can reach up vertically infinitely, you can still only extrude 15 inches outside of your perimeter.
Better example, imagine sitting in a box you are allowed to reach up as high as you want straight up. The second you stick your hand 16 inches out of the box you get slapped on the wrist and told "no"
HERO 俺を讃える声や 喝采なんて 欲しくはないさ
I liked my team more before they stole my jacket.
Play is for kids this is serious...
Unread 30-01-2016, 15:51
laplacier's Avatar
Rookie Year: 2015
Re: Extension
G17 also says quite clearly you cannot exceed 4ft 6in until 20 seconds remain. That means any extension vertically outside of that would be in violation of that rule. It says nothing about extending out the 2D plane around the robot, so the 15 inch extension rule applies there.
Unread 30-01-2016, 16:12
Re: Extension
In your scenario you would never be able to reach high enough to scale the batter. This makes little sense.
I haven't actually done the math on it but from the videos I've seen released it looks possible the issue teams have been hitting is rotating frame perimeters.
Unread 30-01-2016, 16:15
Ekcrbe's Avatar
Ekcrbe Ekcrbe is online now
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Re: Extension
What? How? A number of CAD sketches here on CD have proven that starting from the tower wall and resting on the batter, a mechanism would not have to extend more than 15" outside the robot's frame perimeter to reach the bar, and height is unlimited.
Here's one.
https://plus.google.com/117322302265...2 65076381504
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
Unread 30-01-2016, 16:17
Re: Extension
Here's one.
I never said that a robot had to extend more then 15" outside the frame perimeter to reach the bar. I said that doing so is a rule violation.
Unread 30-01-2016, 16:19
Re: Extension
Nope, it's actually pretty accurate. (Going up the Batter has no relevance to ability to Scale the Tower, BTW. Point of reference.)
You are in a box, extending 15" from your Frame Perimeter, height 4'6". At 20 seconds left in the match, the lid is taken off. The box orients with your robot (in relation to the robot's "flat floor" position).
If at any point you go through the walls or lid of the box, the penalty flags fly.
Unread 30-01-2016, 16:22
laplacier's Avatar
Rookie Year: 2015
Re: Extension
I realized what he meant a little bit later. We were on the same page, but I had assumed he was talking about not being able to reach 15 inches vertically above the robot. It was a misunderstanding on my part.
