Go to Post We can't quite define FIRST according to past standards and traditions, because it is shaping the future and does not conform to today's model of sports. - JaneYoung [more]
Unread 30-01-2016, 16:30
Coach Seb's Avatar
Coach Seb Coach Seb is offline
AKA: Sebastien Cournoyer
FRC #5860 (Full Metal Muskrats)
Rookie Year: 2015
Coach Seb is an unknown quantity at this point
Re: Talon SRX Labview Coding
Originally Posted by ozrien View Post
It sounds there is something in your LV app that is referencing PWM. Maybe the default ArcadeDrive control is still referenced somewhere. Or some test code somewhere. This is why I suggested using the known-working-example first to determine the root-cause of the first issue you mentioned. It sounds like there are multiple problems.
If you post a screenshot, that might help determine what the PWM error is about.
I have an identical program to the one posted and the driver station has more errors
https://www.dropbox.com/s/kapsr1jv6g...83%29.png?dl=0
Unread 30-01-2016, 16:37
Originally Posted by Coach Seb View Post
yeah but we have a CAN network not PWM, how would you change that?
The same way you did in your example.
Change the drop down selection under Open 4 motors to "CAN Talon SRX"
Unread 30-01-2016, 16:44
Coach Seb's Avatar
Rookie Year: 2015
yeah but just to the left of default code is pwm port numbers...
Unread 30-01-2016, 16:46
Those become CAN IDs after you've selected "CAN Talon SRX"
You have to delete the old PWM constants, then Create->Constant to replace them with the new CAN IDs.
