Go to Post I need to start using "ThunderChickens!" as an exclamation - Jessica Boucher [more]
Unread 29-01-2016, 23:17
Massako Massako is offline
FRC #5725 (Cerberus)
Rookie Year: 2015
Massako is an unknown quantity at this point
Chain Tension-er?
We are using #25 chain for a device on our robot and we are fairly new to chain and were wondering how we sould tension it as its at the tighest it can be yet there is still some slip from it drooping slightly does anyone have any ways of applying tension the chain?
Unread 29-01-2016, 23:26
ccresta1386's Avatar
ccresta1386 ccresta1386 is offline
AKA: Collin Cresta
FRC #4954 (Palindrome Robotics)
Team Role: Driver
ccresta1386 is an unknown quantity at this point
Re: Chain Tension-er?
Are you using a chain tensioning tool to assemble the chain?
If taking a link off seems like too much you may need a half link.
Edit: picture of tensioning tool.
https://www.google.com/imgres?imgurl...DIIQMwgwKAEwAQ
FRC Team 4954 2014-?
Torvando's Avatar
Torvando Torvando is offline
Build Team Captain
AKA: Taylor Noble
FRC #2823 (The Automatons)
Torvando is an unknown quantity at this point
For my team's chassis we used rounded Delrin bolted onto the frame. I don't think that this is the best method but it fit and it works. You can also have a spinning pice of Delrin or bearing that the cabin runs on.
Unread 30-01-2016, 01:08
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
You can add an idler sprocket somewhere along the chain's length. Put the sprocket inside a slotted hole or use metal that has several holes to move it around, which will tension and detension the chain. IF your team can afford it, McMasterCarr sells spring-loaded tensioners here.
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 30-01-2016, 05:27
TikiTech's Avatar
TikiTech TikiTech is offline
Mr. H
FRC #3880 (Tiki Techs)
TikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really niceTikiTech is just really nice
Great suggestions
If budget is an issue. These types of tensioners are used on many cars on the timing chain.
For Rebound Rumble we got one off a junk Toyota (free ) and used it on our chain driven ball delivery system.
Works great.
Even new they are not a deal breaker.
Such as the OSK listed here.
http://www.autopartswarehouse.com/sh...er/toyota.html
Nice thing about the car ones, besides being durable, they are wider and you can offset your chain groove.
Good time to create a connection with an auto parts store in the area.
Aloha!
Team 3880 - "Tiki Techs" "Mr. H" - Tiki Technologies Coach / Mentor
Kealakehe High School Robotics - Kailua-Kona, Hawaii
__________________________________________________ _____________________________
2016 Hopper Division | Orlando Regional Engineering Inspiration Award | Hawaii Regional Chairman's Award & Finalist & Woodie Flowers Finalist
2015 Carson Division | Silicon Valley Regional Engineering Inspiration Award | HI Regional Regional Winners & Engineering Inspiration & Deans List Finalist
2014 Newton Division | Hawaii Regional Engineering Inspiration Award & Deans List Finalist
2013 Newton Division | Inland Empire Regional Regional Chairman's & Creativity Award | Los Angles Regional Engineering Inspiration Award | | HI Regional
2012 Curie Division | Hawaii Regional Engineering Inspiration Award
2011 Newton Division | Hawaii Regional Regional Winners & Industrial Design Award
Unread 30-01-2016, 06:46
scaryone's Avatar
scaryone scaryone is offline
FRC #0058 (The Riot Crew)
scaryone will become famous soon enough
If the chain is long enough, an easy ghetto chain tensioner is to wrap a sturdy tie wrap between the two. I thought it was a dumb idea, but it does work.
Unread 30-01-2016, 19:56
Breadbocks Breadbocks is offline
FRC #1002
Breadbocks is on a distinguished road
My team had one of these things sitting around while we were chaining this year's robot and we couldn't get the right tension with just shortening links. We have no idea where it came from or if we have another somewhere, but we tossed it in one section and it works beautifully. We fully intend to use more of them to tension our chain if we can find where the darn thing came from.
Unread 30-01-2016, 20:15
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Two things:
First, if you are transferring torque to the sprocket (i.e. it is not an idler sprocket), you really want to try to get over 120 degrees of wrap on the sprocket. It isn't a hard and fast rule but it is pretty reliable. I've had a number of cases where I reconfigured routings to get over 120 degrees of wrap, chains that were jumpy and poppy and just creeping me out have settled down and I've never had to worry about them again. 120 degrees of wrap. It's a big deal.
Second, it is almost always a mistake not to design chain tensioning into things from the start. You can sometimes get by without it (especially if you can have good wrap angles on all your torque transferring sprockets). Idlers are a nice option depending on your chain routing. I am a fan of moving one of the axles -- even wheel axles which can be done successfully.
My suggestion is that when you use slots to provide your adjustment, do not depend soley on the clamp load of screws to keep your center distances from moving. If you have some slots in a bracket, then have another screw that helps take the load if the screws that are in that slot loosens up. I am doing a terrible job of explaining this. Here is a photo of the concept on a BMX bike chain.
Finally, chain tensioning by moving center distances is more easily done with dead axles where you can use eyebolts as your adjustment mechanism.
Joe J.
Team #88, TJ2
Unread 30-01-2016, 22:45
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
If you are REALLY tight on resources, one of the simplest tensioning techniques is to stick a big sprocket into the middle of the loose chain run - without actually attaching the sprocket to anything - it just floats in the middle of the chain run. The sprocket has to be big enough to take up all the slack, and is held in place by the chain run itself, with chain running above and below it holding it "securely" in place.
Don't know if this makes sense, but it does work decently well. Surprisingly the sprocket won't fall out unless directly disturbed...
This is a hack we used on 188 pretty effectively back in the early days.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 30-01-2016, 23:10
Generator of Entropy
FRC #2973 (The Mad Rockers)
If your device doesn't require the entire chain to travel around a sprocket (for a linear section of a device that travels back and forth) we found this works very well.
Unread 30-01-2016, 23:48
Rookie Year: 2015
lol thanks. i dont know how well this would work on a drive train but we can defiantly try it.
Unread 31-01-2016, 08:10
AKA: Dr. Joe
FRC #0088 (TJ2)
MCMASTER sells a dohicky that works like that. Only for #35 chain and bigger but it at least confirms the concept.
Dr. Joe J
Team #88, TJ2
Unread 31-01-2016, 08:31
eneubec1 eneubec1 is offline
FRC #5090 (Torque-Nados)
eneubec1 is an unknown quantity at this point
Our team was in the same situation last year. We use 16' of chain to drive our lifting mechanism to lift totes/bin. We spent 2 days trying to figure out how to tension the chain, and in the end decided we didn't need one. Those 2 days would have been nice to have back and have some drive practice.
We went the entire season and never had a problem with our chain.
Unread 31-01-2016, 13:37
FRC #1002
Originally Posted by Joe Johnson View Post
MCMASTER sells a dohicky that works like that. Only for #35 chain and bigger bit it at least confirms the concept.
Dr. Joe J
So that's where what we had came from. Why on earth does that cost $70?
Unread 31-01-2016, 13:43
AKA: Dr. Joe
FRC #0088 (TJ2)
I saw that, yeah, $70 is crazy for a bit of plastic (or rubber or silicone or whatever). One thing to keep in mind is that while it may keep your chain from derailing it is not going to do anything for the backlash as you go from fwd to rev and vice versa. Not a huge deal on wheels (probably) but feedback loops hate backlash so... ...keep that in mind (and do the right thing, put in a real chain tensioner ;-)
Dr. Joe J.
Team #88, TJ2
