Go to Post FIRST should never come before school and anyone who thinks otherwise is irresponsible and should not be mentoring the kids - Koko Ed [more]
Unread 25-01-2016, 13:32
j3084985 j3084985 is offline
j3084985 is an unknown quantity at this point
Info on KOP Window Motor
Looking for specifications and CAD model for the current KOP Window Motor. Can anyone point me towards this? Thanks.
Unread 25-01-2016, 14:52
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Info on KOP Window Motor
A quick google search found this.
http://www2.usfirst.org/2006comp/Specs/Denso_Motor.pdf
Before posting such a simple question again, do some searching on google, or by even using the search tool here on Chief Delphi.
On another note, welcome to Chief Delphi
Unread 25-01-2016, 15:39
Fields's Avatar
Fields Fields is offline
Classic
Rookie Year: 2015
Fields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to allFields is a name known to all
Not much info on the output gear used.
Unread 25-01-2016, 16:08
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Here is the actual link from the mechanical resources page on the FIRST website:
https://firstfrc.blob.core.windows.n...ndow-Motor.pdf
This is not the same link as above. This link has info about the current motor. Make sure that you are double checking part numbers before blindly trusting the first result that comes up.
edit: Additionally, links to CAD can be found through some of the CAD software links on the KOP page: http://www.firstinspires.org/resourc...6-kit-of-parts
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 25-01-2016, 16:12
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Does anyone have a lead on a source for a gear to interface with that?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 25-01-2016, 16:19
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
just searched "module 2 spur gear" in Google.
[url="http://www.amazon.com/s/?ie=UTF8&keywords=module+2+spur+gear&tag=googhydr-20&index=industrial&hvadid=61475292187&hvpos=1t3&h vexid=&hvnetw=g&hvrand=4842673932157800023&hvpone= &hvptwo=&hvqmt=b&hvdev=c&ref=pd_sl_a6n7lwbwi_b"]
Unread 30-01-2016, 00:10
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Does anyone know the proper electrical connector for this years KOP window motor ? It isn't on any data sheet I can find at FIRST.
Ed Barker
Unread 30-01-2016, 21:36
bdaroz's Avatar
bdaroz bdaroz is offline
Programming Mentor
AKA: Brian Rozmierski
FRC #5881 (TVHS Dragons)
Rookie Year: 2016
bdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud ofbdaroz has much to be proud of
I've been searching for info on gears/gearboxes or anything to do with this motor, and thank you for some good information.
However, it looks like all 3 sets of CAD files for the 2016 KoP (Autocad, PTC, & Solidworks) all reference a 6-tooth version of the motor -- but the 2016 KoP seems to have changed to a 7 tooth version.
Unread 30-01-2016, 21:45
ebarker's Avatar
AKA: Ed Barker
If you look at the data sheet in Liz's post above it has the gear info, but not the connector info.
Ed Barker
Unread 30-01-2016, 21:57
bdaroz's Avatar
Programming Mentor
Rookie Year: 2016
Thanks Ed. I had seen that, but to be honest, I can barely make heads or tails of it. I'll send it off to one of the other mentors who's an engineer and see if he can figure something with it.
Unread 02-02-2016, 11:03
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
I have followed all the links and still can not find the CAD model that matches the drawing as linked above.
Can someone provide the file?
For those interested I have been able to generate a similar gear profile from this website.
Unread 02-02-2016, 12:35
bdaroz's Avatar
Programming Mentor
Rookie Year: 2016
I'm in the same boat. We modeled the gear in AutoCAD and the team is 3D printing a test adapter to validate the drawing later today. If it fits correctly I'll post the file for everyone. (It's just the gear/cog, not the entire part, but it's a start, and honestly, we all stink at CAD )
Unread 03-02-2016, 01:01
bdaroz's Avatar
Programming Mentor
Rookie Year: 2016
So we test printed a fitting. Unfortunately it didn't quite fit, but we suspect it was due to the student not setting the print quality settings as high as they should. Visually it's a good fit, so we're hoping the 2nd print run tomorrow will be better.
