Go to Post It's what this is all about. Making dreams happen. - Astronouth7303 [more]
Unread 30-01-2016, 23:13
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
Re: SRX closed-loop problems
Problem solved. Note to myself. seems like enableControl() needs to be called
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 01-02-2016, 02:46
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
ozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant futureozrien has a brilliant future
enableControl() shouldn't be necessary unless disableControl() is called somewhere. OR if you are calling changeMode() but not calling set() immediately after like in Section 16.12 (Talon SRX Software Reference Manual).
Just in case it helps anyone else, a simple Java example for Position Closed-Loop.
https://github.com/CrossTheRoadElec/...bot/Robot.java
Unread 01-02-2016, 12:02
Drive Coach
AKA: Antoine L.
I changed a lot of stuff while debugging, so it might be a combinaison of different things. Everything works fine now
