Go to Post The competition is different - everybody really "wins" by all of the great things teams think of to do for other teams and the community. - Chris Fultz [more]
Unread 30-01-2016, 20:01
MaGiC_PiKaChU's Avatar
MaGiC_PiKaChU MaGiC_PiKaChU is offline
Drive Coach
AKA: Antoine L.
FRC #3360 (Hyperion)
MaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond reputeMaGiC_PiKaChU has a reputation beyond repute
SRX closed-loop problems
Hi CD
My team used the SRX closed loop last year, and we want to use it again this year with the versaplanetary encoders on our drivetrain. I tried doing the same as last year, but it does not seem to work at all.
Basically i have 4 versa planetary gearboxes and one of them has the built in encoder. I use the Follower mode for 3 of them, and the Position mode for the leading one. When I use the method Set(), with distance as a parameter to move, it just runs at full speed until I disable the robot. I tried printing the encoder value, and it goes way over the setpoint, like it doesn't even care.
Anyone ever had this problem? thanks
2012 - 3360 - Junior member
2013 - 3360 - Lead Programmer, Human player
2014 - 3360 - Lead Programmer, Human player
2015 - 3360 - Lead Programmer, Driver
2016 - 3360 - Mentor, Drive coach
Unread 30-01-2016, 20:20
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
Re: SRX closed-loop problems
The Unit scaling is different this year. If using CTRE Magnetic Encoder, the units are in rotations/RPM, not Talon native units. Please read section 17.2 in the Talon SRX Software Reference Manual.
Unread 30-01-2016, 20:55
Drive Coach
AKA: Antoine L.
I am using the CtreMagEncoder_Relative control mode, with a setpoint of 1 and it still goes full speed. I checked and my sensor is not reversed
Unread 30-01-2016, 21:54
Drive Coach
AKA: Antoine L.
I tried using the reverseSensor() method but it does not affect the velocity at all.
Unread 30-01-2016, 23:13
Drive Coach
AKA: Antoine L.
Problem solved. Note to myself. seems like enableControl() needs to be called
Unread 01-02-2016, 02:46
ozrien's Avatar
Omar Zrien
AKA: Omar
enableControl() shouldn't be necessary unless disableControl() is called somewhere. OR if you are calling changeMode() but not calling set() immediately after like in Section 16.12 (Talon SRX Software Reference Manual).
Just in case it helps anyone else, a simple Java example for Position Closed-Loop.
https://github.com/CrossTheRoadElec/...bot/Robot.java
Unread 01-02-2016, 12:02
Drive Coach
AKA: Antoine L.
I changed a lot of stuff while debugging, so it might be a combinaison of different things. Everything works fine now
