Go to Post ah, common sense, not as common as one might think... - Ansem Retort [more]
Unread 31-01-2016, 10:37
axton900's Avatar
axton900 axton900 is offline
Programming Co-Captain
FRC #1403 (Cougar Robotics)
Rookie Year: 2015
axton900 has a spectacular aura aboutaxton900 has a spectacular aura aboutaxton900 has a spectacular aura about
Eclipse FRC 2016 C++ problems
Hello!
Our team has been having a lot of issues with Eclipse and right now we are dealing with the most annoying one.
We are having problems with deploying.
We are able to deploy successfully through Eclipse but when we go into the driver station, we are faced with the message of "No Robot Code" and we are not able to enable the robot or test out our code.
We would appreciate any tips and guidance!
Thanks,
axton900
Unread 31-01-2016, 10:56
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Eclipse FRC 2016 C++ problems
Is there anything on riolog?
If not, it's likely that your program is crashing silently because of errors like dereferencing a null pointer. Have you tried using the debugger?
Unread 31-01-2016, 11:12
axton900's Avatar
Rookie Year: 2015
This year(2016) if the code crashes, it will automatically restart itself so the light would have turned green automatically, so it is not a code issue.
Has anyone else been experiencing this either in JAVA or in C++?
Unread 31-01-2016, 15:52
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Have you updated the plugins recently? There was a bug where the code written would be overwritten with blank code in the cpp file, causing issues when compiling/building. Check out this thread for the update.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 31-01-2016, 19:21
axiomofdarkness's Avatar
axiomofdarkness axiomofdarkness is offline
axiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura about
We have not solved the problem, but have managed to work around it by sshing into the RIO and performing the deploy process manually.
