| View Poll Results: Is your team planning to go under the low bar? | |||
| Yes |
410 | 87.61% |
| No |
58 | 12.39% |
| Voters: 468. You may not vote on this poll | |||
Re: Low Bar
Re: Low Bar
I really don't see the advantage to not Scoring in auto yourself and attempting to prevent team X from doing their multi ball auto the mid line rule and the not prevent crossing rule make that highly unlikely to succeed. Plus the way defenses are laid out they are on opposite sides so main auto action is opposite. I guess it could happen however that seems very unlikely. But who knows? Last edited by Boltman : 31-01-2016 at 11:58. |
Re: Low Bar
Re: Low Bar
Re: Low Bar
How are teams planning to collect balls without getting foul? It seems a lot easier to just hit a ball then it does to intake it. Pretty sure it can be done with a pneumatic cylinder and a couple sticks.
Re: Low Bar
Perhaps I suspect intake to be easier.
#7
Re: Low Bar
Anything involving the center line involves a ridiculous amount of accuracy, so I suppose it may be possible that you're right. That being said, it's a general rule that screwing something up is significantly easier than doing it, and I see no reason to suspect that's not the case here.
#8
Re: Low Bar
Not sure how this thread about the Low Bar got sidetracked into a discussion about 2-ball auton, but here is my question:
How many teams have actually practiced going under the Low Bar WITH the cloth barrier in place? If you have, how would you say that it affects your ability to successfully cross the defense? Also - it may have been stated elsewhere, but please note that the Team drawings of the field specify black iron pipe as the weight for the curtain, while the actual field will have an aluminum pipe - quite a difference in weight! |
#9
Re: Low Bar
[quote=Abrakadabra;1532940]Not sure how this thread about the Low Bar got sidetracked into a discussion about 2-ball auton, but here is my question:
How many teams have actually practiced going under the Low Bar WITH the cloth barrier in place? If you have, how would you say that it affects your ability to successfully cross the defense? We have tried it. You need to make sure you don't have anything on the top of your robot for it to get caught on. It's very easy to get snagged. And you should have some time of roll bars or something else that accomplishes protecting the top of your robot. The bar/fabric will catch on the inside of your robot easily. |
