Go to Post The stated goals of FIRST are to inspire a culture that values science and technology. Inspiration needs Motivation. What motivates people? Competition. - Dmentor [more]
Unread 16-01-2015, 19:34
DarkRune DarkRune is offline
AKA: Dylan Baker-Flynn
FRC #4159 (CardinalBotics)
Team Role: Driver
DarkRune is a jewel in the roughDarkRune is a jewel in the roughDarkRune is a jewel in the rough
Exclamation RoboRio Java Installation Problem
Hello,
Our programmer is currently trying to install java on the roboRio to test some code. However, he is turning up with this error:
java.io.FileNotFoundException:
C:\Windows\.\ejdk-8u6-fcs-b23-linux-arm-vfp-sflt-12_jun_2014.tar.gz(Access is denied)
After this error, we went to Oracle's website to directly download the proper JDK. However, it isn't available anymore.
Any suggestions on what to do?
Unread 16-01-2015, 20:09
ayang548 ayang548 is offline
FRC #3663
ayang548 is an unknown quantity at this point
Re: RoboRio Java Installation Problem
This is the site where you can download it.
http://www.oracle.com/technetwork/ja...ads/index.html
This should work.
Unread 17-01-2015, 00:24
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
Originally Posted by DarkRune View Post
Hello,
Where are you running the installer from? That log says you're running it from the windows directory, which definitely won't work. Please run it from the ~/wpilib/tools directory.
Unread 17-01-2015, 15:10
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
Just for some visibility here, I had some problems deploying Java as well. Our school requires you to use a proxy to connect to the Internet, and while my browser and everything works fine, for some reason the installer was unable to download the JRE (just gave me a white box where the webpage is supposed to be). Used the link above to download and selected the "Already Downloaded" option and everything works fine.
I'm not sure if whatever HTTP Java library that's used honors system proxy settings or not, but it seems not.
17/Jan/2015 14:55:43,749- InternetController: Starting internet check
17/Jan/2015 14:55:44,638- InternetController: Internet check successful, moving to download
17/Jan/2015 14:55:45,590- DownloadController: Loading download page page
17/Jan/2015 14:55:45,591- DownloadController: Loading download page page
17/Jan/2015 14:55:47,891- DownloadController: Loading download page page
17/Jan/2015 15:00:28,081- InternetController: Starting internet check
17/Jan/2015 15:00:29,417- InternetController: Error when attempting to connect to the internet
17/Jan/2015 15:06:02,789- ErrorController: Exiting from error screen
Unread 17-01-2015, 20:20
WPILib Developer
FRC #0190
Hmm, that is odd that Java isn't picking up the proxy. I was under the impression that the JavaFX webview would pick that up automatically, but I'll need to look into it. In the meantime, here's the link: http://www.oracle.com/technetwork/ja...ads/index.html. You need to download the Soft Float package. You should be able to use the instructions in the Java installer, just with your own web browser. After you download it, just use the already downloaded option on the second screen and point it at that downloaded file.
Unread 29-01-2015, 18:42
seshaw415 seshaw415 is offline
AKA: Seiji Shaw
FRC #6000 (Firehawk Robotics)
seshaw415 is an unknown quantity at this point
Thanks for your help! Will try.
(From the programmer on 4159)
Unread 30-01-2015, 19:48
Since Fred posted the link, Oracle updated the jdk and his link points to the new version, which doesn't work with java-installer. Use this link instead: http://www.oracle.com/technetwork/ja...6-2406243.html
Unread 29-01-2016, 14:08
nisvana nisvana is offline
nisvana is an unknown quantity at this point
We are facing a somewhat separate issue. We are able to download the jdk and the jre is extracted correctly. When java installer tries to connect to roborio and install the jre, it fails with:
java.io.IOException: Error when extracting the tar gz: exit code 2
We have confirmed that jre.tar.gz is present in the wpilib/tools/ directory?
Any pointers
Unread 30-01-2016, 07:25
WPILib Developer
FRC #0190
Any pointers
Could you please post the log? It's hard to help with only that to go on.
Unread 31-01-2016, 10:04
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
java4first is an unknown quantity at this point
Just another hint ... since the installer likes to delete the jar file after it gets it installed on the roboRIO - make sure (once you do manage to get the copy of it from the Oracle website) to keep an archive copy somewhere else, or you'll keep having the same problem ...
Unread 31-01-2016, 12:37
WPILib Developer
FRC #0190
What? It doesn't do that, it keeps a copy of the generated JRE in the folder it was run from (usually the tools folder), along with an md5 has of the created JRE for integrity checking.
Unread 04-02-2016, 18:30
Tyler_T Tyler_T is offline
FRC #5866
Tyler_T is an unknown quantity at this point
I'm having the same "Access is Denied" issue. I've downloaded the correct file to put on the RoboRio and the Java Installer program will unpack the file but the it goes to this screen:
When I open click "open folder" to get to the log file, it opens my System32 directory. There is a "LogFiles" folder but it contains other folders that seem to have nothing to do with the Java Installer. Any suggestions on how to fix this or find my log file?
Unread 04-02-2016, 20:20
WPILib Developer
FRC #0190
How are you running the installer? If it's opening the system32 directory, that means it's running from there, and not from the wpilib tools directory. It won't work if run from there, as regular programs do not have write access there.
Unread 06-02-2016, 10:19
FRC #5866
Originally I found the Installer in "C:\Users\TylerT" and it would not run from there, I've also tried running the installer from my desktop but I have the same problem.
Unread 06-02-2016, 11:18
WPILib Developer
FRC #0190
You mean it wasn't in the wpilib tools directory? Do you have the plugins installed? If so, could you try running it from the console in the wpilib tools directory? The command is java -jar java-installer.jar.
