Go to Post When your driver is the "world record holder in Mario Cart" you know it's going to be exciting for the students and stressful for the pit crew. :ahh: - lovelj [more]
Unread 01-30-2016, 01:02 PM
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 is on a distinguished road
Robot Losing communication
My team is having problems with the robot loosing communication when connected through the wifi router. It runs fine when connect by USB. We have imaged the router and the roborio. We are using the stock project with no changes.
Has anyone else seen this problem. If so how did you fix it
2015 Midwest Regional Finalist
2015 Central Illinois Regional Winner
2015 Newton Division Finalist
2015 Newton Quality Award
Unread 01-30-2016, 01:54 PM
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Robot Losing communication
With such a complicated control system, there is not one answer.
  • Go through all of your electrical and make sure it's all tight (tug on the power wires).
  • Are your battery leads bolted down tight?
  • Are you using an Ethernet cable with good clips?
  • Try a different laptop, maybe your current laptop's WiFi doesn't play with with the WiFi on the robot?
  • Are you in a high interference area? Try running your robot somewhere else.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 01-30-2016, 01:58 PM
Describe in more detail what you mean by "loosing communication".
Unread 01-30-2016, 02:07 PM
Bpk9p4's Avatar
FRC #1756
thanks you very much for your fast responses. We just solved the issue. It seems like the computer we were using just need to be restarted and it worked fine. Not sure what went wrong but this seems to have fixed the problem
Unread 01-30-2016, 03:18 PM
If you don't know what went wrong, you really didn't fix the problem. Just made it go away (for the time being).
Unread 01-30-2016, 05:01 PM
Bpk9p4's Avatar
FRC #1756
that is a good point. We are going through test this afternoon to see if we can find the problem. I will let you guys know if i find it.
Unread 01-31-2016, 01:54 PM
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Other people on the forums have reported connection issues with an Autodesk updater running on their system. If you have Autodesk installed, you may want to look into that.
Unread 01-31-2016, 02:47 PM
Bpk9p4's Avatar
FRC #1756
i just did some testing and it looks like that was the problem. When it was on i would lose packets every 10 seconds. When i turned it off the problem was fixed
Thanks for your help
Unread 01-31-2016, 03:37 PM
...it would lose packets every 10 seconds.
Just for future reference, if you had provided the above info in response to the following question:
You would have gotten your answer a day earlier
