Go to Post You can't learn anything without breaking some stuff. - DonRotolo [more]
Unread 30-01-2016, 17:08
powster powster is offline
FRC #1148
powster is an unknown quantity at this point
No Robot Code only in Test Mode
Hi guys. So I have robot code that works just fine when running in the normal mode. However, it's a PID system so we want to use Test mode on the driverstation to find the right PID values. However, we get a No Robot Code error when we try to enable it on test mode! Any ideas what could be the issue?
Unread 30-01-2016, 23:35
Re: No Robot Code only in Test Mode
Install this update if you haven't done so already: http://www.chiefdelphi.com/forums/sh...d.php?t=142565
Unread 31-01-2016, 14:31
FRC #1148
I installed the update yesterday and saw no difference, but I'll try again anyways. Any other suggestions?
Unread 31-01-2016, 14:50
Did you re-export from robot builder after installing the update?
Unread 31-01-2016, 16:02
FRC #1148
Yeah, I did re-export it. Furthermore, it did not fix the file overwriting issue I was having with robotbuilder
Unread 09-02-2016, 15:41
dlsmith dlsmith is offline
FRC #5268
dlsmith is an unknown quantity at this point
We had the same problem yesterday - enabling test mode caused the robot code to die. Has anyone resolved this issue yet? Would be nice if test mode worked for PID tuning etc. Thanks.
Unread 13-02-2016, 17:07
FRC #1148
Test mode is working for me now. I don't think I made any real changes to the code or anything? But it works now. Now I just can't find out how to display the motor speed
