Go to Post If you are "retiring" the old ball, make all the lights green, hang it 8 feet in the air, line up a bunch of 'bots and let 'em shoot poofs. RoboPinata! (warning kids - don't eat the "candy" that falls out!) - Taylor [more]
Unread 31-01-2016, 15:01
catmanjake catmanjake is offline
FRC #4009
catmanjake is an unknown quantity at this point
Secret passage question
What does this actually mean as it confuses me?
3.4.6. Robot to Robot interaction
G20 Robots may only enter or exit their opponents secret passage from/to the opponents courtyard.
Does it mean you can't enter secret passage from neutral zone?
Can you go from courtyard to secret passage to neutral zone?
Thanks.
Unread 31-01-2016, 15:07
Dezion's Avatar
Dezion Dezion is offline
Coach | Strategy Co-Lead | Raawr!
FRC #4935 (T-Rex)
Rookie Year: 2015
Dezion is an unknown quantity at this point
Re: Secret passage question
For your first question:
No, you may not enter your opponent's Secret Passage from the neutral zone. However, you may enter your own Secret Passage from the neutral zone.
For your second question:
You may not go from your opponent's Secret Passage to the neutral zone. However, you may for your own secret passage.
To sum it up: you can go in your Secret Passage anytime, but may only enter or exit your opponent's secret passage through your opppnents courtyard.
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Thanks.
Simplest way I can explain it:
From their courtyard you can enter at will their secret passage but can not exit it into neutral and you high risk being fouled by any touch of their bots while your bot parts are contacting carpet in their SP.
You cannot use their SP to enter their courtyard from neutral.
So unless you are playing a risky defensive strategy the opponents SP is just for accidental entry. I have a feeling most teams will treat it as a no go driving zone, except for possible boulder entry blocking/stealing most likely from their courtyard for some aggressive defensive teams or possible offensive acquisition.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 31-01-2016, 15:11
MrJohnston MrJohnston is offline
FRC #0948 (Newport Robotics Group (NRG))
MrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond reputeMrJohnston has a reputation beyond repute
It means that if you are going to enter your opponents' secret passage (the one connected to the castle where you are scoring boulders), you may only do so from their courtyard. The same goes for exiting. This rule is designed so that robots cannot avoid the defenses in order to score boulders. You may not use their secret passage to go to the neutral zone.
However, you may go in and out of your secret passage wherever you please.
Unread 31-01-2016, 15:45
FRC #4009
Thanks. I think it should be a no drive zone as well but wasn't positive if I was reading it correctly or not.
