Go to Post Transparency is the sign of BAD LARD! - ExcuseBoy [more]
Unread 31-01-2016, 17:18
andrewytiger andrewytiger is offline
FRC #3929
andrewytiger can only hope to improve
Question Bumper Question
We are building a bot with an opening in the front for the ball to enter inside. Upon reading the rules, we found out that each side of the bot must be covered with at least 8 inches of bumper from every corner, unless one of your sides is less than 8 inches, in which case that entire side must be covered. Does this mean that we have to build our bot in such a way that on each side of the gap, there has to be 8 inches of bumper, or does the gap effectively create two separate sides of the bot and we can have shorter bumpers that are less than 8 inches?
Unread 31-01-2016, 17:30
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Bumper Question
a gap in your frame doesn't create a new side of the frame perimeter. if your robot's shape is a rectangle with a gap in the front for balls to come through, the gap and the frame left and right of it all counts as part of that side, so you need a minimum of 8 inches of frame on the left and 8 inches on the right of the gap for your bumpers. i'm sure this has lead many teams to make a robot a minimum of 26 inches wide, 8 inches of frame, 10 inch gap for boulders, 8 inches of frame.
Unread 31-01-2016, 17:55
FRC #3929
Re: Bumper Question
Thank you Austin2046. We are planning on making our bot 28.5 inches wide. Hopefully that will be big enough for easy intake of the ball.
Unread 31-01-2016, 21:27
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
At 28.5" that will leave you a 12.5" opening. Keep in mind with this years bumper rules you may find that even if your bumpers went all the way across the ball "should" lift the front of the bot and roll under. Notice should is in quotes.
Unread 31-01-2016, 23:41
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: Bumper Question
The key thing is that the "FRAME PERIMETER" is always a convex shape. It looks like you got this. In order to admit a 10" boulder without compression, a robot side must be at least 8" + 10" + 8" = 26" long. This is probably too long for that side to abut the tower. Make your decisions and take your chances.
