hello im josh from team 2408 i need help with this issue.
"C:\Users\robotics\wpilib\java\current\ant\build.x ml:208: Assertion failed boolean test. roboRIO Image does not match plugin, allowed image version: 19" we have tried to look at the screensteps website and they were not very clear on how to fix it. how do we fix this problem. Last edited by team2408 : 01-27-2016 at 11:31 AM. |
Re: BUILD FAILED
Make sure you have the latest image and firmware on your rio - image should be 2016v19
http://wpilib.screenstepslive.com/s/...borio-firmware https://wpilib.screenstepslive.com/s...g-your-roborio |
Re: BUILD FAILED
Yes, This. Run through the imaging process to get the roborio in java and make sure you have the latest firmware; You'll be up and running in no time
Re: BUILD FAILED
The more common fix for this is to make sure you aren't re-using a laptop with last years "wpilib" directory on it. For some reason, the new build doesn't delete correctly - and you end up trying to download a version from last year. If you search back in the forum, there are a couple of posts about this same problem right after the start of build. It still fails even if you have the right versions of firmware and Java on the roboRIO - as that isn't the problem. I submitted a documentation update request to WPI to include this in their troubleshooting section ... not sure if it has made it yet.
Re: BUILD FAILED
@java4first - It seems that OP has the correct wpilib installation because it's checking for (2016)v19 and not (2015)v23. That's why I suggested checking the rio image version first.
You have to re image your Rio. The imaging tool comes in the yearly NI download. The latest version right now is (2016)v19.
#7
Re: BUILD FAILED
if you are using eclipse, all you need to do is update it! we ran into the same problem and updating eclipse did the charm
