Go to Post Too often teams forget that pretty isn't always good. - Al Skierkiewicz [more]
Unread 31-01-2016, 22:27
Amo10's Avatar
Amo10 Amo10 is offline
AKA: Andrew Morris
FRC #4468 (LINKS)
Amo10 is on a distinguished road
Vex Pro 3 CIM Ball Shifter WCD 3rd Stage Kit with #35 Chain
Currently, our drive is a 3 CIM Ball Shifter with a WCD 3rd Stage Kit with #25 chain. In the WCD part of the gearbox, we have 2 18 tooth #25 sprockets but we were wanting to switch to #35 chain. When looking at the CAD, it doesn't look possible to run 2 #35 12 tooth sprockets with the WCD addition because of the width and the chain will not fit. Are we missing something or is the only way to use #35 chain with the 3 CIM Ball Shifter WCD 3rd Stage Kit to have only 1 #35 sprocket in the WCD addition to the gearbox and place the gearbox at the end of the drive?
Andrew Morris
Team 4468 (2012-2016)
2016 PCH District Columbus Event Winner
2015 Peachtree Regional Engineering Inspiration Award
2015 Peachtree Regional Finalist
2013 Peachtree Regional Rookie Inspiration Award
Unread 31-01-2016, 22:51
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: Vex Pro 3 CIM Ball Shifter WCD 3rd Stage Kit with #35 Chain
We tried using #35 chain on ours and quickly realized that it doesn't work without doing some modifications that really put the structural integrity of the gearbox at risk. You will need #25 chain.
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 31-01-2016, 22:52
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #1736 (Robot Casserole)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
We added half inch spacers and longer bolts to create the space for a double #35 sprocket.
Unread 31-01-2016, 22:58
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
We have modified a set of these to use 15mm belts. The 4 standoffs that hold the aluminum output plate need to be extended (as in, make your own out of round and hex stock). As the standoffs get longer, you should probably plan for additional support for the gearboxes.
