Go to Post If an alternate is used, all four teams are equal members of the alliance. (Trophies, trips, bling, book tours, custody of the children etc.) - Btower [more]
Unread 31-01-2016, 16:33
JagCode's Avatar
JagCode JagCode is offline
Bring Your "B" Game
AKA: Noah
FRC #2929 (JagBots)
JagCode will become famous soon enough
pic: 2929's Forklift + Climber, almost operational
Unread 31-01-2016, 20:47
JohnFogarty's Avatar
FTC, I have returned.
AKA: @doctorfogarty
Re: pic: 2929's Forklift + Climber, almost operational
I hope you've done the math on the volume of air those cylinders you've chosen will need to extend and then retract.
John Fogarty
Unread 31-01-2016, 22:01
JagCode's Avatar
Bring Your "B" Game
AKA: Noah
FRC #2929 (JagBots)
We have. We debated over what ways we can deploy a winch, but in the end we decided to re-purpose the air cylinders we already had as the deploying mechanism.
They only extend, we'll be using the rest of the forklift to lift the bot (more importantly, the bumpers) over the line.
Unread 01-02-2016, 01:48
Oblarg Oblarg is offline
AKA: Eli Barnett
Did this early on.
As it happens, if you use 1.5''-bore, 2'-stroke cylinders and run them out at 30PSI and in at 60PSI, you're more than covered with two black clippard tanks.
"The breakfast of champions!"
Unread 01-02-2016, 02:43
FRC #1836 (MilkenKnights)
Originally Posted by Oblarg View Post
Did this early on.
PSI drops as you use your tanks. So at some point you won't get quite the full force of your actuators.
