Go to Post From a mentor perspective we get to see shy, timid high school kids become leaders in there community and that folks is where we really are winning. - techtiger1 [more]
Unread 01-02-2016, 04:29
Turing'sEgo Turing'sEgo is offline
Turing'sEgo can only hope to improve
Need help fine tuning vision algorithm
I want to get the outer 4 corners of the targets, but all the methods I've tried are not as accurate as I'd like. Anyone have any ideas as to how I can do that? Image of a few of my attempts
Unread 01-02-2016, 06:48
Re: Need help fine tuning vision algorithm
It looks to me like you have the outer edges. Have you tried to solve for the line intersections?
Greg McKaskle
Unread 01-02-2016, 07:32
lphung lphung is offline
FRC #5994
lphung is an unknown quantity at this point
Hi,
I am not sure what is the vision library you are using. If you are using OpenCV, I could suggest using the function: convexHull.
http://docs.opencv.org/2.4/doc/tutor...hull/hull.html
Unread 01-02-2016, 12:22
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Nice work!
For more accuracy you might try using the Find Edge function (in LabView it's under the Machine Vision palette). Once you have a rough idea of the size and location of the targets, Find Edges can do great things. I'm sure OpenCV can do something similar.
Can you post your code?
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
