Go to Post How come CD doesn't have a "Like" button??? - dlavery [more]
View Poll Results: What percentage of robots will be EFFECTIVE Limbo Robot in Week 4 and Beyond
0-19% 21 9.01%
20-39% 60 25.75%
40-59% 92 39.48%
60-79% 44 18.88%
80-99% 16 6.87%
Voters: 233. You may not vote on this poll
Unread 31-01-2016, 18:54
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Percentage of EFFECTIVE Limbo Robots
According to the poll Low Bar 90% of teams are planning on being able to go under the low bar.
I believe that 90% of teams are going to TRY to go under the low bar, I just don't think that there will be that many that are effective at it. By which I mean that their robot can not only go under the low bar but can do something else that adds significant value to their alliance (e.g. cross many/most other defenses, score boulders into the high goal, scale the tower, block opponent shots/play defense effectively, ...).
So... What percentage of teams do YOU thing will be effective Limbo Robots?
For the purposes of this survey, let's not count weeks 0-3 of the season. Answer based on Week 4 and beyond.
Team #88, TJ2
Unread 31-01-2016, 19:00
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Re: Percentage of EFFECTIVE Limbo Robots
Around 20%. Of the remaining 80%, about half will go under the bar, but would have been better off otherwise.
Unread 31-01-2016, 19:22
VacioArconte's Avatar
VacioArconte VacioArconte is offline
Appreciator of Robots
FRC #2468 (Team Appreciate)
Team Role: Electrical
VacioArconte is a jewel in the roughVacioArconte is a jewel in the roughVacioArconte is a jewel in the rough
Keep in mind that Chief Delphi polls disproportionately represent more experienced FRC teams. That 90% probably will not hold true once competitions start up.
That being said, I expect 100% of low bar bots to be able to either shoot low or cross many defenses.
I'd guess 40% of low bar bots will have mechanisms that shoot high, and 50% of those to work fairly well.
I would expect 20% of low bar bots to have hanging mechanisms, and 50% of those to work well.
Unread 31-01-2016, 19:42
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Defining : EFFECTIVE
Low goal scoring is not considered such?
We assume most low bots can assist or cross at least two defenses (Low and open from back doors) so one more qualifies?
Think the poll to be accurate needs to be defined better.
For instance...A low bot that is super fast intakes like no other and can score eight low goals seems "effective" to me.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 31-01-2016, 22:24
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
I agree that the term effective should be defined a little bit better. Are you referring to robots that can not only go under low bar and do something meaningful with a boulder, are you talking about robots who can get under the low bar but the only other thing that their good at is getting over some of the obstacles what is your criteria?
Unread 31-01-2016, 22:42
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Everybody seems to have low bar as a pretty firm requirement, and for good reason. Few teams making low goal scorers will have a problem getting under the low bar (unless they completely miss the geometry of the ramp and design 16" high and do not test). Most teams capable of scoring high consistently will engineer their way through it. I think that by week 4 more than 60% of teams will be able to traverse the low bar at least as efficiently as any other defense, so I checked 60-79%.
Unread 31-01-2016, 22:43
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
I'm interested to see what a robot does if it can't cross a defense or go under the low bar.
461 Westside Boiler Invasion
45 Technokats
Unread 31-01-2016, 22:47
Wait for a partner to open the Group C Defense, or focus on defense in its own courtyard (or at one other point...). Could also play shuttle, dropping off boulders for partners in the Neutral Zone, but that's a risky business.
Unread 31-01-2016, 22:50
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
If I had that bot, I would want to start in the spy position. That way, I could get 5 points for challenging, have access to boulders and goals, and be able to open drawbridges and sally ports.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 01-02-2016, 07:09
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Being a really good rebounder/shooter that can hang would seem to be an effective robot in many matches. Especially with the small upper goal I expect a lot of missed shots in qualifying matches. I think their value would decrease as Saturday goes on however.
Unread 01-02-2016, 08:04
Billfred's Avatar
Billfred Billfred is offline
I don't know about 100%, because teams that just build a kitbot (with all the foibles that usually follow) are likely to fall into this category. Call it 70-80?
Unread 01-02-2016, 09:05
Joining the 900 Meme Team
FRC #0079
0-19%... why? Because that's about the percentage of robots that seem to reliably do the game challenge anyway.
How many will continue to tell you they do it and are 110% accurate into the high goal? If the number of teams in 2014 who told me they always scored a ball in auto is any indicator it'll be something like the remaining 81%. And they'll all scream about me being "un GP" when I point out data to the contrary of their delusions.
Maybe I'm just a grumpy old man already.
Unread 01-02-2016, 09:17
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Nope, you're right. It's 2014 all over again
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 01-02-2016, 09:29
Master of Tactics
AKA: Scott Hasek
FRC #1987
I tend to agree teams say they'll be able to go under the low bar and maybe the can in teleop under the right conditions and little pressure. But come competition time are they going to be able to do something once in the courtyard.
Unread 01-02-2016, 09:45
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Your stated criteria for being EFFECTIVE is not our criteria.
Last year, investing design and practice resources on the coop task might help you in quals, but was worth nothing in eliminations. This year, coop task 1 is crossing defenses, which helps you both in quals and gives bonus points in eliminations. Coop task 2 is achieved by scoring low goals and parking on the batter, also giving bonus points both in quals and eliminations.
Our criteria for a fully effective robot, and one we would be happy to pick for an alliance member, is the ability to quickly traverse defenses (to earn the first bonus) and to quickly score low goals (to earn the second bonus). These can easily be accomplished by a robot that fits under the low bar.
In my view, the most damaging action a robot can take is to shoot for the high goal and miss, robbing your alliance of the second bonus. The possible benefit of a high goal over a low goal (3 points) is not worth the risk of taking that shot (losing 25 points) unless your shooter is greater than 80% accurate (not bloody likely) AND you have time to make all 8 shots into the high goal. (Which, at 80% accuracy, means attempting 10 undefended shots.)
That said, the temptation to waste resources on a mechanism with low point power (high goal shooter) can be overwhelming. I suspect that many teams will go down that road, making mediocre shooters, missing high goal shots and costing their alliances the bonus points for capturing the tower. Those are the teams our scouts will be identifying and avoiding like the black plague.
So, to answer your poll with more than just checking a box, I believe 90% of teams COULD make an effective Limbo bot. 50%-60% of teams will make a robot that physically could be effective. But, only 10% of teams will actually use that robot in an effective gameplay strategy.
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
