Go to Post I firmly believe that - those [GDC] committee members I have met, even briefly, certainly have a passion for what they are doing and want to give teams and students the best possible experiences. - GaryVoshol [more]
Unread 30-01-2016, 13:26
The Doctor's Avatar
The Doctor The Doctor is offline
Robotics is life
AKA: Hackson
FRC #3216 (MRT)
The Doctor is on a distinguished road
Roborio comms with arduino over USB
Recently I've been experimenting with sending status codes to an Arduino from the RoboRio. I've so far tried toggling serial from the MXP to the arduino, and serial over USB between them. Neither of these have worked yet. I was wondering if any teams had input on how to send single byte status packets?
Current robot code (java):
arduino = new SerialPort(19200,SerialPort.Port.kUSB);
byte mode1 = 0;  //////// 0b<red><blue><fms><auton><teleop><disabled><enabled><attached>
				if (ds.getAlliance() == DriverStation.Alliance.Red)  mode1 |= 0b10000000;
				if (ds.getAlliance() == DriverStation.Alliance.Blue) mode1 |= 0b01000000;
				if (ds.isFMSAttached())                              mode1 |= 0b00100000;
				if (ds.isAutonomous())                               mode1 |= 0b00010000;
				if (ds.isOperatorControl())                          mode1 |= 0b00001000;
				if (ds.isDisabled())                                 mode1 |= 0b00000100;
				if (ds.isEnabled())                                  mode1 |= 0b00000010;
				if (ds.isDSAttached())                               mode1 |= 0b00000001;
				byte[] mode2 = {mode1};
				arduino.write(mode2, 1);
The problem is that the instantiation of the SerialPort object causes the robot code to error and restart. The exact error can't be copied out of the DS, but it's something along the lines of this:
RuntimeException: HAL: -VISA: Resource not found at [SerialPortJNI.serialInitializePort]
Has anyone gotten Rio-to-Arduino comms to work using Serial?
Robots + Python + pentesting == me;
Blog ~ GitHub ~ Keybase
If you have a pressing issue to discuss with me, kik me at slush.puddles since I don't check CD very often.
Unread 30-01-2016, 13:48
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Roborio comms with arduino over USB
I got it working. I never tried an Uno or Mega, but the Pro with the FTDI USB to Serial does work. The Uno or Mega might work, but the Uno clone using a CH340 or CH341 USB to Serial did not work.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 31-01-2016, 22:58
mikhail's Avatar
mikhail mikhail is offline
AKA: Mentor of The Software ERRORs
FRC #3130 (ERRORS)
mikhail is an unknown quantity at this point
How do you guys specify which USB port of the RoboRIO to use? We have a webcam and an Arduino board plugged into the two RoboRIO ports. I can be wrong but it seems that the robot code tries to talk to a wrong device sometimes. Can I do something more specific than kUSB? Thanks.
Unread 01-02-2016, 07:43
RyanN's Avatar
RyanN
LabVIEW enumerates the ports for me. I guess since it's running Linux that you can find the port under/dev/ttyUSB0 or something similar.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 10-02-2016, 22:00
Justin Buist Justin Buist is offline
FRC #4003 (TriSonics)
Rookie Year: 2015
Justin Buist is an unknown quantity at this point
USB doesn't really have "ports." The two ports on the roboRIO are basically the same hole, if you will, much like putting a USB hub into one doesn't make 6 new addressable spaces, it's just more holes on the bus.
Your Arduino will show up as /dev/ttyUSB0 or /dev/ttyACM0 in some cases, like a Mega.
The webcam will show up as /dev/video0, then /dev/video1, etc, as you add cameras assuming they're supported in Video4Linux.
The addressing is basically the responsibility of the OS unless you want to get far deeper into USB specs than I have ever bothered.
