Go to Post Seats are seats, we're all watching the same thing. - katiyeh07 [more]
Unread 01-02-2016, 08:14
Jsteel Jsteel is offline
Jsteel is an unknown quantity at this point
Staying on the Batter at the end of the match
How are teams planning on ensuring that their robots don't roll backwards off the Batter after the end of the match when power is killed? There is a 3/4 inch cleat there, but not sure that is going to stop this year's robots.
This assumes, of course, that you are not hanging
Unread 01-02-2016, 08:23
scrblnrd3 scrblnrd3 is offline
FRC #4795
scrblnrd3 is an unknown quantity at this point
Re: Staying on the Batter at the end of the match
Setting your motor controllers to brake mode at the end ought to do it
Unread 01-02-2016, 08:28
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
That might help a little, but it will not hold the robot still. Brake mode depends on the motor generating a back EMF which they don't do at zero speed.
