Go to Post "Your really pretty and I like your bot" - prettycolors91 [more]
Unread 30-01-2016, 13:31
dszlucha dszlucha is offline
FRC #1518 (Raider Robotics)
Rookie Year: 2016
dszlucha is an unknown quantity at this point
Network Table Viewer / GRIP issue
Hello!
I'm trying to use the Network Table Viewer in server mode to display contour values from GRIP on my machine but whenever I try to start the Network Table Viewer in server mode using:
java -jar OutlineViewer.jar
and then use 127.0.0.1 as the host/address I get the following error:
platform: /Mac OS X/x86_64/
NT: ERROR: bind() failed: Address already in use (workspac:102)
The Network Table Viewer comes up but only display ">Root" which is empty.
The GRIP documentation states that the Network Table Viewer can be used in server mode to display values on my local machine.
Its there something else I need to do to get the Network Table Viewer working in server mode on my machine?
Thanks!
David
Unread 31-01-2016, 17:54
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
Re: Network Table Viewer / GRIP issue
That error is printed out by OutlineViewer, not GRIP, right? Are you sure you're not running another instance of OutlineViewer?
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 01-02-2016, 07:57
Rookie Year: 2016
Hi Thomas.
That's correct. The error is coming from the Outline Viewer and not GRIP. I do not seem to have this problem on Windows, only Mac. I do have FRCSim installed on the Mac but it is current not running.
David
Unread 01-02-2016, 09:26
fsilberberg fsilberberg is offline
WPILib Developer
AKA: Fred Silberberg
FRC #0190
fsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura aboutfsilberberg has a spectacular aura about
It sounds like something else on your computer is using port 1735. You're going to have to track down what it is and shut that program down. StackOverflow has an article on how to list open ports: http://stackoverflow.com/questions/4...rt-on-mac-os-x.
Unread 01-02-2016, 17:10
Rookie Year: 2016
I did a lsof -i:1735 which turned out to be a hung java process. Went to Activity Monitor and killed it.
Outline Viewer runs fine now - can view data from GRIP.
Thanks!
David
Unread 01-02-2016, 21:31
Rookie Year: 2016
I'm trying to mock up some code to read the Network Table using the "desktop" package of networktables.jar, e.g., NetworkTables-3.0.0-20151121.170557-4-desktop-development.jar but I am not able to read values from the table. I'm running the Outline Viewer and can see the values there, but not in my own code.
NetworkTable table = NetworkTable.getTable("/GRIP/myContoursReport");
System.out.println(table.containsKey("area"));
Output:
false
Is there anything special I need to do in my client code to initialize NetworkTable?
Thanks!
David
Unread 01-02-2016, 23:12
FRC #0237
I think you need to leave out the leading slash.
PHP Code:
NetworkTable table NetworkTable.getTable("GRIP/myContoursReport");
Unread 02-02-2016, 03:10
Peter Johnson Peter Johnson is offline
WPILib Developer
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
PHP Code:
Yes, that should fix it. This has been fixed in the latest release, but David is using 20151121 rather than the latest release (David, I also recommend you upgrade with the latest version from http://first.wpi.edu/FRC/roborio/mav....0.0-SNAPSHOT/ .. as of this writing it's 20160115).
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 02-02-2016, 16:58
Rookie Year: 2016
Thanks Thomas and Peter for the replies.
I grabbed the latest networkltables jar: NetworkTables-3.0.0-20160115.192917-3-desktop.jar, started up the outline viewer choosing localhost and server, fired up GRIP and could see the Contours report being published via the outline viewer:
/Root/GRIP/myContoursReport/area etc...
But then had the same result in my java code with the addition of an additional error:
Code is in main():
NetworkTable table = NetworkTable.getTable("GRIP/myContoursReport");
System.out.println(table);
Output is:
NetworkTable: /GRIP/myContoursReport
false
If I put back the old networktables jar the error goes away but I still can't read data from the network table.
David
Unread 02-02-2016, 18:08
WPILib Developer
FRC #0190
What code are you using for setup? Are you putting ntcore into client mode, and set up the team correctly? Relevant documentation is here: http://first.wpi.edu/FRC/roborio/rel...workTable.html.
Unread 02-02-2016, 18:28
Rookie Year: 2016
Hi Fred.
I've added NetworkTable.setClientMode() as well as NetworkTable.setTeam(1518) to my code and verified that GRIP is set to team 1518 as well. I've also switched back to a Windows box which also has the "desktop" build of networktables.jar but I'm still not reading from the table:
NetworkTable.setClientMode();
NetworkTable.setTeam(1518);
Output:
platform: /Windows/amd64/
false
Unread 02-02-2016, 18:54
WPILib Developer
FRC #0190
David, you'll need to set the ip to wherever you're actually running the NetworkTables server. It looks like you're not running a robot currently, but using OutlineViewer as the server, right? If that's the case, you'll want to point NetworkTables at 127.0.0.1, not call setTeam.
Unread 02-02-2016, 19:09
Rookie Year: 2016
I appreciate the help but unfortunately it's still not working in "desktop" mode, e.g., not on RoboRIO after setting IP address, e.g., NetworkTable.setIpAddress(), setting client mode and not setting team.
Running Outline Viewer in "server" mode, IP 127.0.0.1. Running GRIP and can see contour values in Outline Viewer. Running the following code in main():
NetworkTable.setIPAddress("127.0.0.1");
//NetworkTable.setTeam(1518);
Output:
false
Unread 02-02-2016, 19:45
WPILib Developer
Can you post your full program? Is your posted code running in some kind of loop so NT actually has time to connect? Note all the NT calls are non-blocking so if your main() code just simply runs these statements and exits it probably never even had a chance to connect. NT will print "CONNECTED" when it successfully connects to the server.
Unread 02-02-2016, 20:39
Rookie Year: 2016
I was just printing out values once in main(). I added a loop and a delay and now see the "NT connected" message and can now read values from the network table.
Thanks for the help!
David
