Go to Post But now we know what's inside Shaun's backpack! ...Don Rotolo's plastic egg. - MishraArtificer [more]
Unread 01-02-2016, 10:30
Sauce-ome Sauce-ome is offline
FRC #4388 (Ridgebotics)
Sauce-ome is an unknown quantity at this point
Inexpensive Slip Ring for Turret
Hello CD!
I'm the programming and electrical lead for team 4388 and we are wanting to create a turret for our robot and we hope to make it turn more than 360 degrees. I have done some research on slip rings that can carry enough current and 8 conductors for motors and signal but have had no luck finding any that aren't very expensive, around the $600 range. If anybody knows any good slip rings I'm open to options and alternative methods.
Thanks!
Unread 01-02-2016, 10:54
Sperkowsky's Avatar
Sperkowsky Sperkowsky is offline
Professional Multitasker
AKA: Samuel Perkowsky
FRC #2869 (Regal Eagles)
Sperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond reputeSperkowsky has a reputation beyond repute
It is week 4. A turret is a very complex design element. By the time you get the parts needed to make it, it will be week 5 or 6 and you will probably not finish. Sorry to be so blunt but I've been in that position with an unfinished robot and do not want to see anyone else in they position.
Unread 01-02-2016, 11:02
RyanShoff RyanShoff is offline
FRC #4143 (Mars Wars)
RyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to beholdRyanShoff is a splendid one to behold
Re: Inexpensive Slip Ring for Turret
We used these last season:
http://www.ebay.com/itm/LARGE-CURREN...item19f8151b35
Not quite what you wanted, but close.
Ryan Shoff
4143 Mars/Wars
CheapGears.com
Unread 01-02-2016, 11:25
Joining the 900 Meme Team
FRC #0079
a) Turrets are complicated, do you REALLY need it.
b) Turrets without slip rings are fairly common. You just have to have extra wire to wrap. You won't have infinite travel but you can do more than 360.
c) Slip rings with those criteria ARE expensive. I've got some that can handle one motor that's pretty cheap. Much past that... yeah nope.
Unread 01-02-2016, 11:27
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Schedule aside, please reread R9 (specifically H. in the blue box) and R11.
Many slip rings contain mercury.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 01-02-2016, 11:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Six wires should be enough for two motors with feedback, if you can get enough power through two 30A breakers. Put two Talon SRXs on the turret. Run power for them and one CAN pair. Terminate the CAN bus on the turret so you don't need it to return. Then wire sensors to the SRX inputs. You have four limit switches and at least two encoders or analog sensors you can connect, getting all that info back and forth through two wires.
Unread 01-02-2016, 11:37
FRC #0079
Are you certain that the implementation of CAN used on the RoboRIO will operate in a noisy environment like that? I know that some implementations are capable of that but I don't know the details behind ours (or those implementations). From what I understood the more noise you deal with the less speed the bus operates with.
Unread 01-02-2016, 11:48
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Personally, I would question the requirement for unlimited rotation. You don't need something that can do absolutely everything in every situation. If you can reduce complexity by building to just 90% of anticipated situations, then I'd do that and give yourself more time for debugging and driver practice.
2016: Lake Superior WFFA
Unread 01-02-2016, 11:56
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
I would agree with Jon. In 2012, my team (at the time) had far more range than we ever used on the turret. The fact is, you can rotate your robot with its drive train to get close to where you want to aim, then use a finer grained adjustment on a turret to do final alignment. Will save a lot of time and your drivers will do this anyway, even if you have >360 deg rotation on the turret. So a lazy susan with a cable tether is likely the right solution here, IMO.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 01-02-2016, 12:24
Thanks for the feedback. Thinking about it now it does seem overkill but it still might be something good to test in the future to see if the CAN bus would work with that much noise along with the amount of current needed to run motors.
Unread 03-02-2016, 08:09
Sauce,
You can redesign the position of your controllers so that you don't have to pass CAN through the turret. this should reduce your wire needs. You can also parallel lower current contacts to increase the amount of current you can pass to the turret.
I agree with others, that for this game, continuous 360 degree freedom is not needed. You can easily get 500 degrees of rotation without the need for a slip ring design.
Unread 03-02-2016, 08:15
346CADmen's Avatar
346CADmen 346CADmen is offline
FRC #0346
346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold346CADmen is a splendid one to behold
Only because you asked. The Mercotac models are small and versatile. But I too think this (revolving turret) might be overkill for this game.
Unread 03-02-2016, 08:17
Mercotac received that name because they contain mercury. They are not legal for FRC robots.
Unread 03-02-2016, 08:26
346CADmen's Avatar
FRC #0346
Thank you Al, your of course correct. I had overlooked that aspect, but as an inspector you of course hadn't. Had just used one in a work application and had it come to mind when I read the question.
Unread 03-02-2016, 08:32
This is not to say that Mercotac parts are bad and are in fact used in a variety of applications. I talked to an application engineer at Mercotac and he told me that if temperature or current specs are exceeded, mercury could exit the part, albeit in very small quantities. This is one of those parts that is listed as "mercury wetted" as opposed to "mercury filled" contacts.
