Re: Sub-Class CANTalon to represent 3 motors
I thought the same at first (when I started writing this), and figured I could use super for most of the functions I needed. But I realized as I was writing this that each function that will get called and actually DOES anything needs to be @Overrid and pointed to all three Talons. Unless there is a function in CANTalon that simply IDENTIFIES the CANTalons, that doesn't DO anything that needs to be overridden (eg public String getType() {return "CANTalon"}, it would be simpler. He has a point, there is no reason TO implement CANTalons unless there is said identifying function
Ultimately, it comes to not having to call the super constructor, and I will go with notmattlythgoe that directly implementing SpeedController is better |
If anyone is looking to group together multiple motors under a single Motor object (i.e. three drivetrain motors under one object like OP's code), I'd like to point to a library of 1902's that has a class called MotorGroup. It works like so:
MotorGroup leftDrive = new MotorGroup(CANTalon.class, 0, 1, 2); leftDrive.setPower(1); MotorGroup rightDrive = new MotorGroup(new CANTalon(3), new CANTalon(4)); rightDrive.setPower(-0.5); The link to the source file (and the rest of the repo) can be found here. To get completely back on-topic and to answer the original question, that wrapper class should work fine. My only suggestion would be to not extend CANTalon. Disclaimer: MotorGroup relies on other parts of the library to exist, so it does not work as-is without changing it not use BCNLib classes. Last edited by Oromus : 01-02-2016 at 13:03. |
CanTalons have a Follower mode, where set() takes the CAN ID of a talon to constantly copy speed from. That way, you only need to pass 2 "master" talons to RobotDrive and have the rest copy those.
http://www.ctr-electronics.com/talon...ical_resources |
Would that be more "reliable" then setting them all in code?
The slave/follower features of the Talon SRX are reliable. Many teams were successful using this feature last season. You can read more about it in the Talon SRX Software Reference manual.
Check out section 16.33 for a specific example of a solution to your OP. http://www.ctr-electronics.com/talon...ical_resources |
#7
Yup, that's because MotorGroup is part of an overall wrapper/utility library that effectively creates it's own, better versions of WPILib's classes. To get MotorGroup to work with WPI's RobotDrive, you just make it implement SpeedController instead of extending Motor and rename a few functions.
