Go to Post Don't just build a robot; build up your community. - Pat Arnold [more]
Unread 01-02-2016, 11:49
wazateer1 wazateer1 is offline
FRC #3506 (YETI Robotics)
wazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to beholdwazateer1 is a splendid one to behold
Sub-Class CANTalon to represent 3 motors
Hi everybody,
This year our team is going with a 6-motor drive train, and our programming team came across the problem of RobotDrive only having two motor and four motor constructors. We only have a tank drive, but I personally like using RobotDrive because of the ease of switching between Tank drive and arcade drive. I saw an old post from 2010 mentioning adding a whole new constructor to the RobotDrive file itself, but I wanted to take a different approach.
Would there be anything wrong with writing our own sub-class of CANTalon (or any class that implemented SpeedController, we are just using CANTalons), whose constructor creates three instances of CANTalons, and overrides .set() by calling .set() on each of the Talons, then constructing RobotDrive with two objects of this class, one for each side of the drive train?
Code outline (not guaranteed to compile )
public class ThreeMotorGearbox extends CANTalon {
    public CANTalon talon1, talon2, talon3;
    public ThreeMotorGearbox(int talon1id, int talon2id, int talon3id) {
        super(talon1id); //We will be overriding all the important methods, anyway)
        talon1 = new CANTalon(talon1id);
        talon2 = new CANTalon(talon2id);
        talon3 = new CANTalon(talon3id);
    @Override
    public void set(double speed) {
        talon1.set(speed);
        talon2.set(speed);
        talon3.set(speed);
//Somewhere in the code
public ThreeMotorGearbox leftSide, rightSide;
public RobotDrive driveTrain;
leftSide = new ThreeMotorGearbox(1,2,3);
rightSide = new ThreeMotorGearbox(4,5,6);
driveTrain = new RobotDrive(leftSide, rightSide);
Unread 01-02-2016, 11:51
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Sub-Class CANTalon to represent 3 motors
Originally Posted by wazateer1 View Post
Hi everybody,
    @Override
        talon1.set(speed);
        talon2.set(speed);
        talon3.set(speed);
You'd probably be better just implementing the SpeedController class.
Edit: SpeedController
Unread 01-02-2016, 11:52
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Originally Posted by notmattlythgoe View Post
You'd probably be better just extending the MotorController class.
Why?
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 01-02-2016, 12:07
Flywheel Police
Originally Posted by lethc View Post
Why?
The SpeedController is the base interface for all of the motor controllers. This way you know you are implementing all of the stuff that needs implemented. Really it should just be calling the same method that you're implementing for each of the CANTalons.
Unread 01-02-2016, 12:20
Why?
I thought the same at first (when I started writing this), and figured I could use super for most of the functions I needed. But I realized as I was writing this that each function that will get called and actually DOES anything needs to be @Overrid and pointed to all three Talons. Unless there is a function in CANTalon that simply IDENTIFIES the CANTalons, that doesn't DO anything that needs to be overridden (eg public String getType() {return "CANTalon"}, it would be simpler. He has a point, there is no reason TO implement CANTalons unless there is said identifying function
CANTalon does implement SpeedController, by extending it my class inherits all the functions, plus the way CANTalons identify themselves
Ultimately, it comes to not having to call the super constructor, and I will go with notmattlythgoe that directly implementing SpeedController is better
Unread 01-02-2016, 12:57
Oromus's Avatar
Oromus Oromus is offline
Lead Programmer, Community Liason
AKA: Ryan
FRC #1902 (Exploding Bacon)
Oromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to beholdOromus is a splendid one to behold
If anyone is looking to group together multiple motors under a single Motor object (i.e. three drivetrain motors under one object like OP's code), I'd like to point to a library of 1902's that has a class called MotorGroup. It works like so:
MotorGroup leftDrive = new MotorGroup(CANTalon.class, 0, 1, 2);
leftDrive.setPower(1);
MotorGroup rightDrive = new MotorGroup(new CANTalon(3), new CANTalon(4));
rightDrive.setPower(-0.5);
MotorGroup is very flexible because it takes any type of Motor and can contain as many motors as you want, so it should help eliminate having to make awkward wrapper classes or mass-call SpeedController.set().
The link to the source file (and the rest of the repo) can be found here.
To get completely back on-topic and to answer the original question, that wrapper class should work fine. My only suggestion would be to not extend CANTalon.
Disclaimer: MotorGroup relies on other parts of the library to exist, so it does not work as-is without changing it not use BCNLib classes.
2016 Roles: Manipulator, Strategy Co-Lead, Programmer
2016 Orlando Regional: Quarterfinalist (Captain w/ 1557, 5557 and 4352)
2016 Rocket City Regional: Quarterfinalist (w/ 283 and 34), Regional Chairman's Award Winner
2016 Championship: N/A (had fun and was inspired, that's what counts)
2015 Role: Programmer
2015 GSCR: Quarterfinalist (w/ 4189 and 4026), Regional Chairman's Award Winner
2015 Orlando Regional: Semifinalist (w/ 456 and 86), Imagery Award Winner
2015 Championship: Pit Safety Award Winner
Unread 01-02-2016, 13:03
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
CanTalons have a Follower mode, where set() takes the CAN ID of a talon to constantly copy speed from. That way, you only need to pass 2 "master" talons to RobotDrive and have the rest copy those.
Unread 01-02-2016, 13:23
ozrien's Avatar
ozrien ozrien is offline
Omar Zrien
AKA: Omar
+1. Check out section 16.33 in talon srx software reference manual.
http://www.ctr-electronics.com/talon...ical_resources
The only problem with that is RobotDrive does not know to call .setPower, it only every calls .set() assuming any class that implements SpeedController uses that method
Unread 01-02-2016, 13:25
Oromus's Avatar
AKA: Ryan
Yup, that's because MotorGroup is part of an overall wrapper/utility library that effectively creates it's own, better versions of WPILib's classes. To get MotorGroup to work with WPI's RobotDrive, you just make it implement SpeedController instead of extending Motor and rename a few functions.
Unread 01-02-2016, 13:26
Would that be more "reliable" then setting them all in code?
Unread 01-02-2016, 14:13
ozrien's Avatar
Omar Zrien
AKA: Omar
The slave/follower features of the Talon SRX are reliable. Many teams were successful using this feature last season. You can read more about it in the Talon SRX Software Reference manual.
Check out section 16.33 for a specific example of a solution to your OP.
Unread 01-02-2016, 15:32
Thanks all!
