Go to Post You can't please all the people all the time. The rationale of "lots of people don't like it" is not a reason to stop doing it. - Karthik [more]
Unread 01-02-2016, 12:34
bfk bfk is offline
FRC #2521
bfk is an unknown quantity at this point
Bearings falling out of rhino plates
I noticed that after running our Rhino drivetrain around for a little while that the bearing supporting the drive shaft on the outer plate has slipped along the shaft and was no longer giving any support. The bearing could be easily pushed in and out with finger pressure. The flange is on the inside so the bearing ran along the shaft rather than fall to the floor. Looking more closely we saw that the bearings on the inner plate were also very loose. This happens on at least three of the four rhinos we have.
For the drive shaft we can add spacers and there's always Loctite, but has anyone else seen this?
Unread 01-02-2016, 12:38
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: Bearings falling out of rhino plates
Typically flanges bearings will ONLY guarantee the bearing won't move in one direction. Even if you have a tight press fit on the bearing, it will loosen up over time. So, it's important to make sure you constrain your bearings in the other direction as well! This can often be done with spacers - we keep some 1/2" ID PVC pipe on hand to cut to the proper length when needed. It can also be done with shaft collars, or if you have a lathe you can cut a groove and use an E clip. In fact, we're using all 3 of these methods on our robot this year!
2016: Lake Superior WFFA
Unread 01-02-2016, 13:00
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Yes I posted about that in another thread here, and even talked to Andy about it. We put a hex collar on the shaft rather than a spacer.
Unread 01-02-2016, 13:04
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
I suspect you missed something during assembly. The bearings should be retained one way or another so they do not float out. The direction they are inserted is often important.
Unread 01-02-2016, 13:10
dradel's Avatar
They didn't miss anything. Bearing is supposed to be "press fit" but the hole in plates are not quite press fit
Unread 01-02-2016, 13:21
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Would a drop of 'LockTite sleeve retaining compound' help close the distance in the bearing press fit?
I've used that before on slightly worn, or shafts designed to be undersized for plating but were not plated, to hold things in place.
Better to have the plate machined properly but in a pinch...
Unread 01-02-2016, 13:22
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
We occasionally drill a small hole next to bearings and screw in a sheet metal screw so head just touched the bearing.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 01-02-2016, 13:23
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
You can also cut an e-ring groove with a hacksaw.
Unread 01-02-2016, 13:51
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Likely nothing was missed. I noted the surprising lack of spacer/retention for the flanged bearing on the outer plates(when oriented with the flange inside). This confirms my suspicion though that a spacer should be added.
Unread 01-02-2016, 14:11
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
As you observed, the light press will not retain the bearing. It might be worthwhile to ask AndyMark. They are very supportive of their products.
Unread 01-02-2016, 14:52
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
It's pretty much always worth contacting FRC suppliers before you start posting on Chief Delphi when you have issues with their products-- I've found them to be almost universally highly responsive and helpful.
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
