Go to Post ...SEARCH BEFORE YOU POST, and when you do post think twice before pressing the 'post' button. - Brandon Martus [more]
Unread 01-02-2016, 11:28
aphelps231's Avatar
aphelps231 aphelps231 is offline
Andrew Phelps
FRC #1318 (Issaquah Robotics Society)
aphelps231 has a spectacular aura aboutaphelps231 has a spectacular aura about
Do GT2 belts work on HTD pulleys reliably?
For a drive train, would GT2 belts work on HTD pulleys? Specifically, a 5mm pitch GT2 belt from sdp-si.com on the AndyMark 42 tooth pulley. I wasn't able to find any HTD belts of the right size that weren't sold out, and I saw that the GT2 belt shape is similar to the shape of HTD belts.
team1318.org
2016: Flight Director, Alliance/Match Strategy
2015: Mechanical Lead
2013-2014: Fabrication
2016: 2x district finalists, Quality, DCMP Entrepreneurship Awards
2015: 3x district winners, Innovation in Control, Creativity, Team Spirit awards
2014: Galileo Division finalists, PNW District Championship winners, 1x district winners, District Chairman's, Innovation in Control, Entrpreneurship awards
2013: Entrepreneurship award
Unread 01-02-2016, 11:32
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Do GT2 belts work on HTD pulleys reliably?
According to Gates, it will work, but is not recommended. They will have a reduced torque rating. They also say not to use HTD belts on GT2 sprockets. The only time we used 5 MM belts on the drive train, we had issues with them breaking. But then our competition driver was a mad man. We changed to 15 mm belts since I couldn't change the nut behind the sticks.
Unread 01-02-2016, 11:35
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
What is the right size? Vex has lots of sizes in stock http://www.vexrobotics.com/vexpro/mo...ts-and-pulleys
They also have a great calculator for finding the right size:
http://www.wcproducts.net/how-to-belts/
Unread 01-02-2016, 12:21
Chris is me's Avatar
AKA: Pinecone
This does work, yes. I've heard that it is slightly stronger than HTD belts on HTD pulleys, but not as strong as GT2 belts on GT2 pulleys. But this does work - 2791 used this method in 2012 and 2013 to power their drivetrains.
Unread 01-02-2016, 13:21
Knufire Knufire is offline
The 5mm that the OP referenced is the pitch, not the belt length. Nearly all pulleys sold by FRC suppliers are 5mm HTD, either 9mm or 15mm wide. You were probably referring to the latter?
Team 469: 2010 - 2013
Team 5188: 2014 - 2016
NAR (VEX U): 2014 - Present
Unread 01-02-2016, 13:50
FrankJ's Avatar
Robot Mentor
FRC #2974 (WALT)
(Duh) Silly me. We had bad luck with the 9mm wide and switched to 15mm wide. They are both 5mm pitch as you correctly pointed out. YMMV depending on transmitted torque & pulley size.
aphelps231's Avatar
Andrew Phelps
Somewhere between 120 and 130 teeth. I found belts with 125 and 127 teeth, but they were all out of stock.
team1318.org
Unread 01-02-2016, 14:10
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Have you tried B&B?
Unread 01-02-2016, 16:45
Bennett548 Bennett548 is offline
Engineering Mentor
AKA: Steve Bennett
FRC #0548 (Robostangs)
Bennett548 is just really niceBennett548 is just really niceBennett548 is just really niceBennett548 is just really nice
Depending on what width you need SDP/SI has some in that length range, but all their stock looks a little low.
https://sdp-si.com/eStore/Catalog/Pa...%206R25M125090
Unread 02-02-2016, 00:54
InFlight's Avatar
InFlight InFlight is offline
3574 - The King's of Bling
AKA: Jim
FRC #3574 (High Tekerz)
InFlight is an unknown quantity at this point
I've used Vbeltsupply.com several times. Also Amazon has HTD belts.
The part number Is length_mm - 5M - width_mm
Your 127 tooth belt would be a 635-5M-15, a quick search on the correct Gates P/N should yield plenty of supplier options.
Thank you 2016 Alliance Partners - 948, 1510, 2046, 2521, 2980, 2990, 4911, 4683
Unread 02-02-2016, 01:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Has anyone else had issues with belt calculators coming up short on center to center distance? Our belts are a lot looser than we'd like then to be, using the distance provided on the WCP calculator.
Unread 02-02-2016, 03:06
Just to double check, does the WCP calculator match the SDP-SI calculator?
https://sdp-si.com/eStore/CenterDistanceDesigner
Unread 02-02-2016, 12:00
AKA: Pinecone
Proper tension for a belt is surprisingly loose in my experience. It shouldn't be skipping or anything, but the belts do have a little give. I've found teams that manually tension belts tend to over tension which decreases belt life.
